board maple-mini, no BMP upload option et al (gdb)
Post by zmemw16 » Thu Oct 08, 2015 11:20 pm
or am i as usual missing something
so i thought i'd try out the BMP i'd flashed, got throughly confused and ended up with 2 BMP'd pills, one of each
sussed that and re-BMP'd the red one, now it's ~/bin/write-BMP explicitly using ~/bin/BMP/st-flash from the the arduino upload log and the ~/bin/BMP/blackmagic.bin file from the first post zip file.
changed the blue pill to a blue BAITE mini, of course the photo having both red pill bmp and baite target wired together was a good reason
i set the board as maple-mini and there's no BMP upload option.
looked at the circuits and i think it can be set to be a generic stm32f103 option c8t6, which would return the BMP option
lsusb gives
Bus 003 Device 124: ID 1d50:6018 OpenMoko, Inc.
Bus 003 Device 115: ID 1eaf:0003
and device wise it's
$comms ## another ~/bin ls -lt /dev | egrep 'ttyA|ttyU'
crw-rw----  1 root dialout   166,   0 Oct  8 16:15 ttyACM0
crw-rw----  1 root dialout   166,   1 Oct  8 16:15 ttyACM1
lrwxrwxrwx  1 root root             7 Oct  8 12:50 maple_2 -> ttyACM2
crw-rw-r--  1 root dialout   166,   2 Oct  8 12:50 ttyACM2
when i tried it with the original two pills i got through the gdb bit to the line
target extended-remote /dev/ttyACM0
as in the first post http://www.stm32duino.com/viewtopic.php?f=37&t=122#p989 where it froze? hence the re-arrange of pills/baite
versions arduino 1.6.5 stm32duino as of 090915 i thought, excepting that the STM32duino-bootloader and drivers directories are 220915 for some reason; but it's pretty much the latest/current github
actually that's been static for a while:-) i keep looking..
i'll re-read that thread again as i'm not quite sure which ACM port to use for upload
i think it's
acm0 is bmp/gdb
acm1 is for upload through to target
acm2 is arduino serial monitor
Re: board maple-mini, no BMP upload option et al (gdb)
Post by Rick Kimball » Thu Nov 05, 2015 10:59 pm
If you use a terminal emulator at 115200 (typically /dev/ttyACM0), the BMP port will print
$OK#9A
/dev/ttyACM1 is the virtual com port
Things to check:
1.) udev permissions
