f407vet6 & f407zet6
Re: f407vet6 & f407zet6
Post by ahull » Mon Aug 14, 2017 9:42 am
zmemw16 wrote:
Sun Aug 13, 2017 12:25 pm
the zet is remaining rather high at about $15
zgt not seen
srp
At that price, you might be tempted to go for a Pi Zero W instead of the ZET
Post by zmemw16 » Mon Aug 14, 2017 3:46 pm
as usual it's the add on bits that hike the price, basic £9.60, with the extra connectors it's £14 :(
it's horses for courses, the zgt Devils Cross is rather nice for IO and pretty much sorted connectors wise, micro usb, micro sd and dupont leads, sadly no built in ethernet :lol:
Post by ag123 » Mon Aug 14, 2017 3:52 pm
zgt not seen
srp
yup & if you don't mind a 'clone' there's orange pi for even less
https://www.ebay.com/sch/i.html?_sop=15 ... =450&rt=nc
http://www.orangepi.org/orangepizero/
but without all that fancy adc, dac, fancy multiple spi, i2c and more gpio pins than do one can count with fingers + toes etc
:lol:
Post by zmemw16 » Mon Aug 14, 2017 3:55 pm
and that add on expansion bit is $11 :D
srp
Post by ag123 » Mon Aug 14, 2017 4:06 pm
oh and that stm's f40x ART accelerator and DMA controller may dwarf all those 'bigger' chips running at 1 ghz, in particular for running apps directly from flash. but of course the pi win by simply running it off megabytes of dram
:lol:
Post by ag123 » Mon Aug 14, 2017 4:22 pm
i've always been wondering if stm32f4xx kind of high performance mcus may after all one day run 3d printers more than simply those 'dumb' 3d printer controllers that just interpret gcodes and move the motors.
perhaps one day we may be able to pack an octoprint http://octoprint.org/ clone and do away with the host, send your g-code file, stm32f4* controller does all the rest (level bed, control temperature, control all the acceleration / deceleration (i.e. do *physics calc* f = ma, accelerate & extrude faster in a long stretch then slow down towards the end etc) and run the lcd show a fancy lcd with print progress, temperature etc with a fancy gui to to control pretty much all aspects of the print and on top of all that stream a video showing the print in progress sending it over wifi to your web browser
my guess is, the main limit as always is *memory*
one of those things that comes fairly close to that for now is beaglebone black + replicape
https://www.thing-printer.com/product/replicape/
as after all beaglebone black has the dram & storage to run a full linux distribution
:lol:
acronis
Post by acronis » Sat Sep 09, 2017 3:37 am
Hello.
Why can not I use AnalogRead ?
pinMode(PA0, INPUT);
  while (!Serial) {
    delay(1);
 Serial.println(analogRead(PA0));
Post by RogerClark » Sat Sep 09, 2017 8:22 am
try
acronis
Post by acronis » Sat Sep 09, 2017 9:27 am
In this library not working for some reason analogRead.
As You wrote - also not working.
When reading the readings are always 0.
although the level is changed to PA0
If I put the library https://github.com/danieleff/STM32GENERIC - the same code is working fine.
What could be the problem ?
Post by fpiSTM » Sat Sep 09, 2017 9:38 am
On which board you use it ?
because PA0 is connected to user button on some boards... so default pull down I guess...
Or PA0 on f407 could be used for Uart4
Edit: Button could not explain why it works with Daniel Core....
