[libmaple] Black F407VET6
acronis
Re: [libmaple] Black F407VET6
Post by acronis » Sun Oct 15, 2017 12:43 pm
Steven Thank you.
This error is gone , but there were other
dc_read:412: error: base operand of '->' has non-pointer type 'const adc_dev'
on line
dataPoints[j+1] = ADC2->regs->DR & ADC_DR_DATA;
void fetch() {
//  const adc_dev *dev = PIN_MAP[analogInPin].adc_device;
  int channel = PIN_MAP[analogInPin].adc_channel;
  adc_set_sample_rate(&ADC1, ADC_SMPR_1_5); // ADC_SMPR_13_5, ADC_SMPR_1_5
  adc_set_sample_rate(&ADC2, ADC_SMPR_1_5); // ADC_SMPR_13_5, ADC_SMPR_1_5
  adc_set_reg_seqlen(&ADC1, 1);
  adc_set_reg_seqlen(&ADC2, 1);
  ADC1->regs->SQR3 = channel;
  ADC2->regs->SQR3 = channel;
    ADC1->regs->CR1 |= 0x70000; // ADC_CR1_FASTINT;
  ADC1->regs->CR2 |= ADC_CR2_CONT | ADC_CR2_SWSTART;
  ADC2->regs->CR2 |= ADC_CR2_CONT | ADC_CR2_SWSTART;
  ADC2->regs->CR1 |= 0x70000; // ADC_CR1_FASTINT;
  nvic_globalirq_disable();
//  uint32_t t = micros();
  // .584 uS
  for (int j = 0; j < maxSamples ; j+=2 )
    while (!(ADC1->regs->SR & ADC_SR_EOC))
    dataPoints[j] = ADC1->regs->DR & ADC_DR_DATA;
    while (!(ADC2->regs->SR & ADC_SR_EOC))
  nvic_globalirq_enable();
Post by stevestrong » Sun Oct 15, 2017 4:10 pm
Oh well, I see your point, there are many places which use ADC as a pointer and not as the structure address.
The ideal solution would be to change the ADC module of F4 to be compatible with F1.
Till then, you can replace ADCx by (&ADCx).
acronis
Post by acronis » Sun Oct 15, 2017 11:32 pm
Hello Steven !
I hear You.
You did a great job by adding support STM32F4.
I really hope that You will be able to add support for ADC on this Board.
acronis
Post by acronis » Thu Oct 19, 2017 11:37 am
Hello Steven
Rewrote all the code in &ADCx, but the error persists
dataPoints[j+1] = &ADC2->regs->DR & ADC_DR_DATA;
In this line, correct the code ?
Post by stevestrong » Thu Oct 19, 2017 12:13 pm
Use the brackets correctly:
dataPoints[j+1] = (&ADC2)->regs->DR & ADC_DR_DATA;
acronis
Post by acronis » Fri Oct 20, 2017 11:54 am
Hello Steven.
I was able to do as you told me.
The error no longer exists.
But ADC is not working correctly, the values are constantly jumping (subject to change).
I tried to connect the ADC pin to GND and VCC, the values still vary over a wide range.
Tried using analogRead () all the same - value jump from the lower to the upper limit.
Why doesn't ADC ?
It is possible as that to solve ?
Post by stevestrong » Fri Oct 20, 2017 12:01 pm
Very probable that it can be solved.
Just the necessary time is missing...
acronis
Post by acronis » Fri Oct 20, 2017 12:05 pm
Thank You for Your tremendous work.
You have so much done !!!
You're probably only ADC !
We will wait for a quick solution.
Thank You again.
acronis
Post by acronis » Mon Oct 23, 2017 3:06 pm
stevestrong thank you very much for the help !
It worked on another pine !
acronis
Post by acronis » Wed Nov 08, 2017 12:35 pm
Hello steven.
Not if You managed to adapt the I2C for this Board?
