[libmaple] Black F407VET6
vitor_boss
Re: [libmaple] Black F407VET6
Post by vitor_boss » Fri Jun 02, 2017 9:07 pm
stevestrong wrote:I updated the first post with upload information.
vitor, if you still have problems, please post here the Arduino build output.
Which sketch do you try to build? As I told, it builds fine for me (on Win10 64b).
That: https://github.com/VitorBoss/speeduino
C:\Users\Vitor\Documents\Arduino\hardware\Arduino_STM32\STM32F4\cores\maple\libmaple\HardwareSPI.cpp:68:6: error: 'BOARD_SPI3B_NSS_PIN' was not declared in this scope
     {BOARD_SPI3B_NSS_PIN,
C:\Users\Vitor\Documents\Arduino\hardware\Arduino_STM32\STM32F4\cores\maple\libmaple\HardwareSPI.cpp:69:6: error: 'BOARD_SPI3B_SCK_PIN' was not declared in this scope
      BOARD_SPI3B_SCK_PIN,
C:\Users\Vitor\Documents\Arduino\hardware\Arduino_STM32\STM32F4\cores\maple\libmaple\HardwareSPI.cpp:396:81: error: 'const stm32_pin_info' has no member named 'gpio_bit'
                                                      mosii->gpio_device, mosii->gpio_bit);
exit status 1
Error compiling for board Generic STM32F407V series.
Post by stevestrong » Fri Jun 02, 2017 9:10 pm
In Arduino IDE, you have to select Tools->Boards->"Generic STM32F407V series", and after that the Tools->USB Configuration->USB serial (CDC), if you want to have serial over USB.
Post by stevestrong » Fri Jun 02, 2017 9:15 pm
You are certainly not using the right software package (branch) because the HardwareSPI stuff should not exist at all in my latest version...
check here: https://github.com/stevstrong/Arduino_S ... e/libmaple
Please do a clean install (download & extract) of the mentioned branch.
vitor_boss
Post by vitor_boss » Fri Jun 02, 2017 9:27 pm
My bad, I did a dirty install, but I had downloaded from your master branch earlier
One last question, what library is used on PlatformIO?
edit: Blink sketch uses 11904 bytes of RAM, is that right? maple mini uses 8K
vitor_boss
Post by vitor_boss » Sat Jun 03, 2017 12:49 am
Using the board Serial and a generic USB Serial converter with 'Flash Loader Demo' application is possible to write binaries on processor
vitor_boss
Post by vitor_boss » Tue Jun 06, 2017 8:06 pm
stevestrong wrote:You are certainly not using the right software package (branch) because the HardwareSPI stuff should not exist at all in my latest version...
Do you want a copy of ST MCD library for a SPI base?
Post by stevestrong » Tue Jun 06, 2017 9:35 pm
There is already a working, DMA capable SPI library in the libraries folder. https://github.com/stevstrong/Arduino_S ... es/SPI/src
acronis
Post by acronis » Fri Jun 16, 2017 1:10 pm
Hello.
IDE 1.8.2 , you have the library installed stevestrong has the libraries for 16 bit parallel display and https://github.com/stevstrong/Adafruit_ ... 6bit_STM32 https://github.com/stevstrong/Arduino_S ... F4_variant . example Graphisctest. error
In file included from C:\Users\VIC\ Documents\Arduino\\libraries Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino:7:0:
C:\Users\VIC\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h in the void writeCommand function '(uint16_t)':
C:\Users\VIC\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:64:22: error: 'fsmcCommand' was not declared in this area
#define lcdCommand (*fsmcCommand)
C:\Users\Виктор\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:68:27 note: in expansion of macro 'lcdCommand'
#define writeCmd(d) { lcdCommand = d; } //(l&0x00FF); }
C:\Users\VIC\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:200:2 note: in expansion of macro writeCmd"
writeCmd ();
Post by stevestrong » Fri Jun 16, 2017 1:14 pm
Please check the very first post of this thread, there is written to use another branch, the generic_f4, which contains the latest developments, also support for FSMC, which the black_f4 branch does not include.
acronis
Post by acronis » Fri Jun 16, 2017 1:29 pm
set . error
C:\Users\51FB~1\appdata\local\temp\arduino_modified_sketch_882808\graphicstest.Ino:1:28: fatal error: libmaple/FCSM.h: no such file or directory
#include <libmaple/FCSM.h>
