[libmaple] Black F407VET6
Re: [libmaple] Black F407VET6
Post by stevestrong » Fri Jun 16, 2017 1:38 pm
You don't have to extra include the FSMC header into the sketch, because it is done automatically within the "Adafruit_TFTLCD_16bit_STM32.h" header file, line 56.
And please do a clean extract of the downloaded ZIP files (both Adafruit 16 bit parallel lib and generic_f4 branch), delete any existing previous files/folders.
acronis
Post by acronis » Fri Jun 16, 2017 1:47 pm
I have done so .
The library just now installed.
#include <libmaple/fsmc.h> more not prescribed
#include <libmaple/FCSM.h> ???? true name ???
FSMC.h ???
Post by stevestrong » Fri Jun 16, 2017 2:41 pm
Sorry, but it is still not clear what you intend to do with FSMC.h or FCSM.h
As I told, you do not have to include any additional header file, the graphic test should run out of the box with FSMC activated.
If you want to disable it, then comment out line 15 of the graphics lib header file.
acronis
Post by acronis » Fri Jun 16, 2017 3:07 pm
Great !
It worked !
Super !
THANK you !
acronis
Post by acronis » Fri Jun 16, 2017 3:17 pm
Tell me more please , where to download a working example for SD Card-based generic_F4 branch of my repo
Post by stevestrong » Fri Jun 16, 2017 3:30 pm
Glad that it worked.
SdFat examples are available in the original SdFat source directory of Bill Greiman on github, please search for it and download it, then place it to library folder of the Arduino working directory.
Currently only the SPI interface is working with SD-cards, you have to choose one SPI port and connect an extra SD-card module to it.
For that please check the SdFat help, it provides information how to use it with STM32.
The on-board SD card slot usage is only possible when using the SDIO interface.
Which is currently under evaluation phase, basically is working very stable, but I need to make more tests to be sure that it works under any circumstance.
acronis
Post by acronis » Fri Jun 16, 2017 3:33 pm
I'm interested in is The on-board SD card slot.
We expect from You information about the testing
acronis
Post by acronis » Fri Jun 16, 2017 3:35 pm
And tell me which library is better to use for working with clocks (RTC) this Board ?
Post by stevestrong » Fri Jun 16, 2017 3:37 pm
acronis wrote:And tell me which library is better to use for working with clocks (RTC) this Board ?
I have no idea what you want to do, and I don't know how to work with RTC. Search the forum.
I will post here when SDIO is ready to be published.
Post by stevestrong » Sun Jun 18, 2017 6:36 pm
The generic F4 repository has been updated with SDIO related files, see http://www.stm32duino.com/viewtopic.php?f=39&t=2215.
