[libmaple] SDIO
Re: [libmaple] SDIO
Post by Pito » Wed Jul 05, 2017 2:01 pm
But it can also be a difference between the boards, since your board is not the "generic black F4VET" one. Is the difference only in the chip or are there other differences?
The only difference is the chip and maybe +/- 1-3cm in SDIO's signal wires length.
The same vendor, similar layout..
My board: http://www.stm32duino.com/viewtopic.php ... =30#p22456
PS: why the write speed in above benchmark is 1/7 of the read speed?
4096,512.36,3560.81
8192,504.73,3560.76
16384,504.18,3524.25
32768,504.84,3522.68
Re: [libmaple] SDIO
Post by stevestrong » Wed Jul 05, 2017 2:21 pm
4096,512.36,3560.81
8192,504.73,3560.76
Good question. Is this a CL4 card? I assume this has to do with the card physical properties.
stephen's results also show saturated values for 4kB (and more) large buffer: viewtopic.php?f=39&t=2215&start=40#p30985
I'll check my results again later today.
I'll post a binary file and a sketch to test in the first post.
Re: [libmaple] SDIO
Post by zmemw16 » Wed Jul 05, 2017 3:33 pm
on my hub i've replaced the wimpy supplied walwart with a 5V 4A capable one
although just about everything hangs off the hub, ols,2x usb serial, stlink and the board.
Re: [libmaple] SDIO
Post by stevestrong » Wed Jul 05, 2017 3:48 pm
I updated the first post with two attachments, one INO example and the corresponding BIN file.
The results today are similar to what I have measured that time (SanDisk Ultra 16GB CL10 card)
Type any character to start.
size,write,read
bytes,KB/sec,KB/sec
512,352.13,1855.96
1024,615.75,2573.66
2048,1273.42,3993.01
4096,3232.87,6568.02
8192,5171.66,8589.67
16384,6754.45,9880.24
32768,8231.03,10657.71
totalMicros  64281101
yieldMicros  44535132
yieldCalls   53279
yieldMaxUsec 134928
kHzSdClk     24000
Done
size,write,read
bytes,KB/sec,KB/sec
512,430.66,2197.68
1024,684.68,2444.70
2048,1424.19,4174.99
4096,3339.52,6118.28
8192,5012.46,8629.27
16384,6870.03,9874.56
32768,8144.14,10624.18
totalMicros  57296702
yieldMicros  38051319
yieldCalls   51383
yieldMaxUsec 116471
kHzSdClk     24000
Done
and this for CL4 card:
size,write,read
bytes,KB/sec,KB/sec
512,185.31,863.50
1024,358.01,1054.87
2048,645.52,2104.41
4096,file.write returned: 4294967295
error: write failed
SD errorCode: 0X60,0X0
no warm-up effect for me, so that I can reliably reproduce the issue.
UPDATE 1
It looks like the writing of the very first 8 blocks group will be timed out by DMA.
Increasing timeout to 1 sec.
UPDATE 2
It seems that more timeout helped:
size,write,read
bytes,KB/sec,KB/sec
512,185.99,860.55
1024,357.34,1056.89
2048,646.17,2090.50
4096,1094.19,4065.31
8192,1094.58,4057.11
16384,1096.93,4040.55
32768,1092.60,4063.81
totalMicros  142184940
yieldMicros  106522579
yieldCalls   115617
yieldMaxUsec 148572
kHzSdClk     24000
Done
I will change the timeout in repo.
Re: [libmaple] SDIO
Post by Pito » Wed Jul 05, 2017 5:36 pm
I've decided to risk :) and I've tried with your binary on Black F407ZET6 board (cards not formatted before the test):
Samsung EVO CL10 8GB
SdFatSdio uses a traditional DMA SDIO implementation.
size,write,read
bytes,KB/sec,KB/sec
512,268.75,1186.61
1024,578.31,2013.27
2048,902.17,3499.82
4096,2799.68,5325.05
8192,4729.74,7705.77
16384,7165.14,9325.13
32768,8636.38,10346.14
totalMicros  79935842
yieldMicros  56356622
yieldCalls   114859
yieldMaxUsec 199834
kHzSdClk     24000
Done
Samsung EVO CL10 16GB
size,write,read
bytes,KB/sec,KB/sec
512,315.42,1295.00
1024,486.53,2033.53
2048,1517.90,3509.05
4096,2738.69,5332.19
8192,4632.94,7709.81
16384,7191.61,9327.00
32768,8425.72,10344.20
totalMicros  73763594
yieldMicros  50792680
yieldCalls   114860
yieldMaxUsec 198584
kHzSdClk     24000
Done
Sandisk Ultra CL10 16GB, card 1.
size,write,read
bytes,KB/sec,KB/sec
512,439.61,1914.48
1024,538.54,2518.62
2048,1441.54,4153.86
4096,3370.35,6156.08
8192,6380.76,8115.88
16384,7596.10,9546.00
32768,9727.74,10468.51
totalMicros  60056059
yieldMicros  40286200
yieldCalls   52631
yieldMaxUsec 74410
kHzSdClk     24000
Done
Sandisk Ultra CL10 16GB, card 2.
size,write,read
bytes,KB/sec,KB/sec
512,362.94,1666.05
1024,602.00,2421.28
2048,1303.10,4093.86
4096,3167.93,6554.75
8192,5363.25,8609.24
16384,6699.70,9865.31
32768,7869.86,10634.55
totalMicros  64457002
yieldMicros  43704083
yieldCalls   51403
yieldMaxUsec 124242
kHzSdClk     24000
Done
Sandisk CL4, 4GB
size,write,read
bytes,KB/sec,KB/sec
512,342.61,1162.36
1024,646.56,1869.17
2048,1118.13,3018.84
error: write failed
Kingston CL4 4GB, after several minutes (and after formatting too):
size,write,read
bytes,KB/sec,KB/sec
512,
I would add a message "Please wait - the 512 test may last for 15 seconds.." otherwise I start to panic.. :roll:
Re: [libmaple] SDIO
Post by stevestrong » Wed Jul 05, 2017 10:39 pm
I updated the first post with new BIN and INO files, a fix was necessary for CL4 cards to work with buffers greater or equal than 4kB.
Additionally I added to monitor log info about the SD card.
And, as requested, the user gets warned about the time to wait.
Re: [libmaple] SDIO
Post by Pito » Wed Jul 05, 2017 10:50 pm
Kingston CL4 4GB (formatted)
This sketch demonstrates STM32F4 SDIO (DMA) implementation.
init time: 7 ms
Card type: SDHC
Manufacturer ID: 2
OEM ID: TM
Product: SA04G
Version: 0.6
Serial number: 289b4188
Manufacturing date: 3/2011
cardSize: 3951.03 MB (MB = 1,000,000 bytes)
flashEraseSize: 128 blocks
eraseSingleBlock: true
OCR: c0ff8000
Volume is FAT32
blocksPerCluster: 64
clusterCount: 120320
freeClusters: 120193
freeSpace: 3938.48 MB (MB = 1,000,000 bytes)
fatStartBlock: 14502
fatCount: 2
blocksPerFat: 941
rootDirStart: 2
dataStartBlock: 16384
FreeStack: 84095
Test started - please wait, it may take up to 3 minutes
size, write, read
bytes, KB/sec, KB/sec
512,
Sandisk CL4 4GB (formatted)
init time: 12 ms
Card type: SDHC
Manufacturer ID: 3
OEM ID: SD
Product: SU04G
Version: 8.0
Serial number: cb65e554
Manufacturing date: 10/2011
cardSize: 3965.19 MB (MB = 1,000,000 bytes)
OCR: c0ff8000
Volume is FAT32
clusterCount: 120752
freeClusters: 120751
freeSpace: 3956.77 MB (MB = 1,000,000 bytes)
fatStartBlock: 14496
fatCount: 2
blocksPerFat: 944
rootDirStart: 2
FreeStack: 84095
size, write, read
512, 350.17, 1140.61
1024, 657.74, 1869.21
2048, 1142.84, 2936.87
4096, 2382.75, 5641.95
8192, 2199.07, 7567.05
16384, 4125.74, 9295.20
32768, 6569.25, 10285.50
totalMicros  73707421
yieldMicros  48709966
yieldCalls   52923
yieldMaxUsec 209866
kHzSdClk     24000
Done
Re: [libmaple] SDIO
Post by stevestrong » Wed Jul 05, 2017 10:55 pm
@Pito, did you wait 3 minutes?
Re: [libmaple] SDIO
Post by Pito » Wed Jul 05, 2017 10:59 pm
Nope, I started to panic.. I'll try again..
Kingston CL4 4GB
Test started - please wait, it may take up to 3 minutes  :)
size, write, read
512, 45.45, 482.42                  in T=00:03:15
1024, 24.92, 693.02                  in T=00:06:05
2048, 25.21, 1286.25                       in T=00:15:00
4096, 1337.13, 2271.51
8192, 1702.51, 3916.33
16384, 3012.27, 5492.42
32768, 3638.46, 7413.43                  in T=00:15:20
totalMicros  914714129             => 15.5minutes
yieldMicros  867872714
yieldCalls   84774
yieldMaxUsec 150782
kHzSdClk     24000
Done
Re: [libmaple] SDIO
Post by stevestrong » Wed Jul 05, 2017 11:01 pm
I might have not attached the very latest BIN previously, so I updated the first post again.
  Demo sketch of STM32F4 SDIO (DMA) implementation.
init time: 8 ms
Card type: SD2
Manufacturer ID: 27
OEM ID: PH
Product: SD02G
Version: 3.0
Serial number: 97bdbf7c
Manufacturing date: 8/2011
cardSize: 1969.23 MB (MB = 1,000,000 bytes)
OCR: 80ff8000
Volume is FAT16
clusterCount: 60086
freeClusters: 59578
freeSpace: 1952.25 MB (MB = 1,000,000 bytes)
fatStartBlock: 138
fatCount: 2
blocksPerFat: 235
rootDirStart: 608
dataStartBlock: 640
FreeStack: 84095
size, write, read
512, 191.49, 872.32
1024, 359.56, 1059.29
2048, 661.10, 2100.89
4096, 1133.47, 4102.19
8192, 1612.33, 5705.51
16384, 1965.11, 7776.31
32768, 2231.90, 9110.85
totalMicros  127501398
yieldMicros  94566913
yieldCalls   87120
yieldMaxUsec 151458
kHzSdClk     24000
Done
