[libmaple] FSMC LCD 16bit
Re: [libmaple] FSMC LCD 16bit
Post by Pito » Thu Jul 06, 2017 4:59 pm
I refer below these two generic Black F407VET6/ZET6 boards:
http://wiki.stm32duino.com/index.php?title=STM32F407
you may get them here:
https://www.aliexpress.com/item/Free-sh ... 22721.html
https://www.aliexpress.com/item/Free-sh ... .64.4hrwhV
There are 2 differences:
TFT funct --- VET -------- ZET
CS         FSMC_NE1     FSMC_NE4
RS         FSMC_A18     FSMC_A6
Acelex TFT-32C for BlackF407VE_ZE.JPG (17.86 KiB) Viewed 480 times
@stephen: you have to adjust the CS and RS signals in your driver for your particular board..
Mind the NE1 or NE4 chipselect signals are set via the FSMC configuration (in case you are using FSMC).
A Chipselect with NE1 means the FSMC device address space (with A18 inside) starts at 0x60000000:
RS = 0 ... you wr/rd at 0x60000000
RS = 1 ... you wr/rd at 0x60040000
A Chipselect with NE4 means the FSMC device address space (with A6 inside) starts at 0x6C000000:
RS = 0 ... you wr/rd at 0x6C000000
RS = 1 ... you wr/rd at 0x6C000040
FYI: A Chipselect with NE3 means the FSMC device address space starts at 0x68000000 - this is the external SRAM's chip space on the ZET board (the pads on the pcb's bottom side)..
In order to get the FSMC configuration, for example in CubeMX, select ChipSelect=NE1, Type=LCD, RegisterSelect=A18, DataWidth=16 and it should generate the FSMC setup for you such it enables only the FSMC address pinXY related to RS=A18, thus you may use the other FSMC related address pins for your own purpose..
Post by stevestrong » Thu Jul 06, 2017 7:23 pm
There is one more thing which you can do: play arround with these values: https://github.com/stevstrong/Arduino_S ... fsmc.c#L79
Increasing them means slower but more reliable access.
These values work for me, but since i dont know your board, it may have other requirements.
Post by Pito » Thu Jul 06, 2017 7:32 pm
FSMC_BTR_DATAST_(6) | FSMC_BTR_ADDHLD_(0) | FSMC_BTR_ADDSET_(2));
I would start with e.g.
DATAST 50 (1..255)
ADDSET 15 (0..15)
as the TFT displays could be slow..
Post by zmemw16 » Thu Jul 06, 2017 8:07 pm
i think i mentioned a18/a6 and said something else changed as well.
that's why i said Steves TFT 16bit library would need attention.
i suppose a #define setting a V|Z flag in the sketch for the library, not the best way i think
i know something like __STMF4__ is set, but is there one distinguishing between V and Z ?
Post by stevestrong » Thu Jul 06, 2017 8:25 pm
Stephen, what you say refers to the v/z difference between the boards.
I think as long as you use the black vet6 board (and it seems that you do, see first post), my software should run on it without any change.
Exept maybe some fine tuning for fsmc, but not more essential.
But now i realize that not all my wires come from the onboard tft socket, i have to check it again.
Post by zmemw16 » Fri Jul 07, 2017 12:31 am
[e3]@Pito your connector for the ZE is wrong[/e3] NOTE TO SELF it's the ZG that has a 34w socket
i wonder if the Black F4 boards need a wiki page all of their own :?:
i have schematics for all 3, VE, ZE & ZG.
i now have pictures of all 3 front & rear
i will have pictures of each display connections silk screen.
any chance of a picture of your setup :?:
i would be very interested in those 'extra' connections :) i don't understand how you have extras though. :?
the displays that i have connect only via the tft header, there are no other connectors available on the display.
i tried the links from my order, it needed a login, so the store is
Numon Electronic Cyberport Store
https://www.aliexpress.com/store/2274002
these links are to the relevant image location.
these i think are for the ZE & ZG, should be 34w and a header on the display
https://ae01.alicdn.com/kf/UT8z8FjX2hXX ... 2b40d25fe8
up to date product
http://ae01.alicdn.com/kf/HTB1JH9SRFXXX ... a5d49c2a2c
for the VE, should be 32w and a socket on the display
up to date product
just confirmed that the pin labelling on some '3.2 LCD MODULES' i got yonks ago is an exact match for the ZE/ZG boards.
[e1]
https://ae01.alicdn.com/kf/HTB1U3PcKXXX ... XFXXXe.jpg
[/e1]
£8.48 & £8.88
KELI Electronics Technology Co., Ltd
i'm a repeat customer of theirs, nothing excessive in price though
https://www.aliexpress.com/store/623118 ... .27.Vqw0Ec
China Electrical Industry Store
maybe, not sure
https://www.aliexpress.com/store/216604 ... 0.0.I1aIWb
Post by Pito » Fri Jul 07, 2017 8:55 am
I've updated my above "headers - TFT connectors" post with links as it seems we starting to introduce a bit of chaos in what we understand as generic Black F407VET/ZET :)
Post by stevestrong » Fri Jul 07, 2017 9:09 am
I was always referring to this (generic) black F407VET6 board (wiki link).
The ZET6 variant on the bottom of the page should be actually detailed, please, one of you who owns that, feel free to add more information.
Post by zmemw16 » Fri Jul 07, 2017 10:54 am
the Numon Electronic Cyberport Store has only the ZGT in stock, but it's dropped a bit in price.
i put up the original pictures of the VE & ZE on the wiki, someone else inserted a board in between them.
first, okular & gimp
now remembering how to upload ?
Post by stevestrong » Fri Jul 07, 2017 1:25 pm
I think I remember now I had problems to set the FSMC_A18 line high (used as LCD_CD(RS) control line), it didn't work.
https://github.com/stevstrong/Arduino_S ... fsmc.c#L69
Instead, another address line, I think A16 worked only in the current configuration, and I don't know why...
Could you check with a scope whether this pin will be set when writing something to "fsmcData"?
