[libmaple] FSMC LCD 16bit
exider
Re: [libmaple] FSMC LCD 16bit
Post by exider » Sat Oct 14, 2017 6:58 pm
@stevestrong
Could any of you try to copy the Adafruit_GFX_AS lib from F1 to F4 lib directory?
Then replace in the 16 bit lib header file
#include <Adafruit_GFX.h>
by
#include <Adafruit_GFX_AS.h>
and tell me wheter it builds and works?
Yes, it builds and it works!
Post by stevestrong » Sat Oct 14, 2017 7:05 pm
Nice, thanks for letting me know.
Then I suggest to use this.
EDIT
I modified the lib to get rid of compiler warnings, find attached here.
Place it under Arduino_STM32/STM32F4/libraries.
Adafruit_GFX_AS library for F4.7z
(15.39 KiB) Downloaded 30 times
Post by zmemw16 » Sat Oct 14, 2017 9:52 pm
yes, i've checked udev scripts and the resultant /dev/tty* permissions, all the same as on my other systems.
@stevstrong
as seems usual for me, i just get the text output via a usb serial block on pa9/pa10, serial usb (ttyACM0) nothing, nothing on tft lcd.
am i correct in thinking the only changes required for using the ze/zg variants would be setting the ne[1-4] block and the address line a6, a10, a18 etc? i've multiple available of those, one(?2?) of the vet
@both can you post a picture of your setups ?
optional :-) maybe screen captures of the tools drop down or just a list of what's set ... ...
maybe try it on windows, like that's going to happen, ok maybe just sleep
Post by stevestrong » Sun Oct 15, 2017 3:52 pm
Here is a short video of my setup: viewtopic.php?f=39&t=2298#p31037
My settings? Just the basic stuff: Win 10, Arduino IDE 1.6.12, Tools->Board: Generic F407VE series, USB serial active.
+ my repo, and my Adafruit 16 bit lib with activated FSMC, and the Adafruit_GFX_AS lib for F4, as attached in my other post above. That's all.
And a correct wiring... ;)
I don't know the ze/zg boards.
EDIT
@stephen, are you sure your LCD board is set to 16 bit parallel access?
StrangerM
Post by StrangerM » Sun Oct 15, 2017 4:10 pm
Hi. I am sorry. I used Arduino 1.8.5 in WinXP. I modified Adafruit_TFTLCD_16bit_STM32 for compilation. https://yadi.sk/d/5gzxn-wu3NmaDk
Post by zmemw16 » Sun Oct 15, 2017 6:04 pm
EDIT
stev have you echoed the 16bit changes into the 8bit ?
that would seem the easiest route.
2017-10-15 18.51.05.png (87.52 KiB) Viewed 206 times
on the back of the display the missing resistors are R1+R6*, R4+R7*,
2nd group is R10*+R11, R12*+R13, R14*+R15, finally R17 above HP2046
* is the fitted side.
wag 1st pair cpu interface 8080/6800/other, middle right
wag 2nd set as colour mode selection ? bottom right
no signal named ALE or similar, no latch IC
@exider, you said exactly same hardware, is the back of your display the same as in that <horrible> picture?
StrangerM
Post by StrangerM » Mon Oct 16, 2017 12:09 am
It`s the back of my display https://yadi.sk/i/cQu3UM1X3Nn3wZ
Post by zmemw16 » Mon Oct 16, 2017 3:15 am
i'd say identical, bad, bad news :( :(
i went looking via my order list on aliexpress for the display, current product is about 30% of the backside components.
could you attach your binary with a rename extension of dot txt
and maybe the source sketch as well ?
this has to be something stupid or so, so basically fundamental i'm completely missing it.
have i mentioned i can kill a system unit, stm32 board or display with a look :D
StrangerM
Post by StrangerM » Mon Oct 16, 2017 12:33 pm
Look throught attentivly my previous attach. There is everything in it - my Adafruit_TFTLCD_16bit_STM32 and arduino_build_857036.
StrangerM
Post by StrangerM » Mon Oct 16, 2017 12:53 pm
In my project Ichanged Adafruit_SPITFT.cpp .
#include "Adafruit_SPITFT.h"
#ifndef ARDUINO_STM32_FEATHER
  #include "pins_arduino.h"
#ifndef RASPI
   // #include "wiring_private.h" !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#include <limits.h>
#include "Adafruit_SPITFT_Macros.h"
