[libmaple] Latest - issues
Re: [libmaple] Latest - issues
Post by Pito » Tue Aug 15, 2017 10:22 pm
Where is the duplicate please??
Post by RogerClark » Tue Aug 15, 2017 10:50 pm
viewtopic.php?f=41&t=2434
"Libmaple problem, program crashes with call to malloc."
You have linked to it yourself
Post by stevestrong » Sat Aug 19, 2017 8:08 am
RogerClark wrote:
Tue Aug 15, 2017 10:03 pm
This is a duplicate post thread and will be removed
OK from my side.
Post by Pito » Sat Sep 02, 2017 10:07 am
While messing with map() function I see it returns wrong results with larger arguments.
It is because the multiplication in map() overflows.
This is a fix which works fine here (there is "long" in the original, I assume "long" == "int32_t"):
 // Fix by Pito 9/2017
  static inline int32_t map(int32_t value, int32_t fromStart, int32_t fromEnd,
     int32_t toStart, int32_t toEnd) {
     return ((int64_t)(value - fromStart) * (toEnd - toStart)) / (fromEnd - fromStart) +
         toStart;
Example:
period = 2000000;
maxduty = 65000;
mypulse =  1000000;
duty = map(mypulse, 0, period, 0, maxduty);
Results:
Original Libmaple's map() -> duty = 287
Fixed map() -> duty = 32500
Post by RogerClark » Sun Sep 03, 2017 1:03 am
I've updated LibMaple F1 and F4 with your fix
(and attributed it to you)
Post by victor_pv » Sun Sep 03, 2017 3:18 am
Pito new.cpp was missing from the libmaple F4. Both Roger and Steve have merged it. That should resolve the issues about malloc, or at least reduce the code size, since it will not pull new from stdlib.
On map(), looks like at least Teensy, and perhaps Arduino, have gone a bit further:
https://github.com/PaulStoffregen/cores ... ring.h#L46
And I saw some conversation on allowing toend < tostart, not sure if that case is covered already?
Post by Pito » Tue Sep 05, 2017 8:57 am
I've seen somewhere (not sure where) the guys did an overloaded map() which worked with all types (as well as with single/double float)..
