alternative way to use STM DFU in Arduino 1.8.3 on Black F407VET6
poiuycat
Post by poiuycat » Fri Oct 06, 2017 9:09 am
this is a demonstrate how to use STM DFU in Ardunio 1.8.3
for those who don't have STLINK do like to download vs USB STM DFU mode
first setup the Black F407VET6 set the jumper from PA0 to BOOT0
Hold the K_UP button and plug the USB cable to PC.
(Due to the design, Hold the K_UP button and press the RESET will not enter to STM DFU mode)
Select Arduino tools to STM DFU and press upload button.
When upload is completed MCU will auto reset and run the code.
and you will see the Upgrade successful !
continue ...... how to setup the STM dfu in Arduino
poiuycat
Re: alternative way to use STM DFU in Arduino 1.8.3 on Black F407VET6
Post by poiuycat » Fri Oct 06, 2017 9:35 am
Download the DfuSe Commandline Master.rar
https://hackaday.io/project/4139-stm32- ... -converter
create a directory in <user>\Documents\Arduino\hardware\Arduino_STM32-master\tools\win\stfdu
unzip to "stfdu" directory
modify the platform.txt in Arduino\hardware\Arduino_STM32-master\STM32F4
change the compiler from binary to ihex , because the upload tools required.
compiler.elf2hex.flags=-O ihex
compiler.elf2hex.cmd=arm-none-eabi-objcopy
## Create hex
recipe.objcopy.hex.pattern="{compiler.path}{compiler.elf2hex.cmd}" {compiler.elf2hex.flags} {compiler.elf2hex.extra_flags} "{build.path}/{build.project_name}.elf" "{build.path}/{build.project_name}.hex"
## Save Compiled Binary
recipe.output.tmp_file={build.project_name}.hex
recipe.output.save_file={build.project_name}.{build.variant}.hex
add stmDFU upload
# stmDFU upload
tools.stmDFU_upload.cmd=stmDFU_upload
tools.stmDFU_upload.cmd.windows=stmDFU_upload.bat
tools.stmDFU_upload.path.windows={runtime.hardware.path}/tools/win
tools.stmDFU_upload.path.macosx={runtime.hardware.path}/tools/macosx
tools.stmDFU_upload.path.linux={runtime.hardware.path}/tools/linux
tools.stmDFU_upload.path.linux64={runtime.hardware.path}/tools/linux64
tools.stmDFU_upload.upload.params.verbose=-d
tools.stmDFU_upload.upload.params.quiet=
tools.stmDFU_upload.upload.pattern="{path}/{cmd}" {serial.port.file} {upload.altID} {upload.usbID} "{build.path}/{build.project_name}.hex"
platform.txt
(8.92 KiB) Downloaded 18 times
modify the boards.txt
change tool to stmDFU_upload
#generic_f407v.upload.tool=stlink_upload
#generic_f407v.upload.protocol=stlink
generic_f407v.upload.tool=stmDFU_upload
add tools menu
generic_f407v.menu.usb_cfg.usb_dfu=STM DFU
generic_f407v.menu.usb_cfg.usb_dfu.build.cpu_flags=-DSERIAL_USB
boards.txt
(5.83 KiB) Downloaded 19 times
create the stmDFU_upload.bat in Arduino\hardware\Arduino_STM32-master\tools\win
@echo off
rem: Note %~dp0 get path of this batch file
rem: Need to change drive if My Documents is on a drive other than C:
set driverLetter=%~dp0
set driverLetter=%driverLetter:~0,2%
%driverLetter%
cd %~dp0
rem: the two line below are needed to fix path issues with incorrect slashes before the bin file name
set str=%4
set str=%str:/=\%
rem: ------------- use STM DFU
"stfdu\DfuSe Commandline Master\BIN\DfuFileMgr.exe" %4 %4.dfu > nul
"stfdu\DfuSe Commandline Master\BIN\DfuSeCommand.exe" -c -d --fn %4.dfu -l
Done . 8-)
PS: I wonder how do I make USB serial work in DFU download.
edit:
thanks stevestrong USB serial work in stevestrong repo
STMdfu_batchfile for Stevestrong repo.rar
(5.82 KiB) Downloaded 20 times
Post by stevestrong » Fri Oct 06, 2017 12:06 pm
You have to add -DSERIAL_USB to the cpu_flags in "boards.txt":
This will compile the USB CDC part of the core so that you will be able to use USB serial after uploading.
poiuycat
Post by poiuycat » Fri Oct 06, 2017 12:27 pm
I did try before adding -DSERIAL_USB in cpu_flags but it wont compile at all !! usb not working and program not blinking.
that why I put -DUSB_NC
and I also tried add compiler.libs with usbF4/VCP , and still no working...... maybe I still miss something ?!?!
compiler.libs.c.flags="-I{build.core.path}" "-I{build.system.path}/libmaple" "-I{build.core.path}/libmaple/usbF4" "-I{build.core.path}/libmaple/usbF4/STM32_USB_Device_Library/Core/inc" "-I{build.core.path}/libmaple/usbF4/STM32_USB_Device_Library/Class/cdc/inc" "-I{build.core.path}/libmaple/usbF4/STM32_USB_OTG_Driver/inc" "-I{build.core.path}/libmaple/usbF4/VCP"
Post by stevestrong » Fri Oct 06, 2017 1:18 pm
Please post here the complete build output, including any error/warning message.
poiuycat
Post by poiuycat » Fri Oct 06, 2017 1:31 pm
this is the complete build output with out any error.
DSERIAL_USB.txt
(81.77 KiB) Downloaded 29 times
Post by stevestrong » Fri Oct 06, 2017 1:44 pm
You wrote that
it won't compile at all!
And I expect that you show us why it does not compile at all, show us the error messages.
Or do you mean that USB serial will not work?
poiuycat
Post by poiuycat » Fri Oct 06, 2017 1:46 pm
DSERIAL_USB.txt
I found something strange !!
if I comment out
//Serial.begin(115200);
//Serial.println("OK!!!!!!!!!!");
complete build will fine and STM serial came out
if I use SerialUSB or Serial complete build OK but not working
SerialUSB.begin(115200);
SerialUSB.println("OK!!!!!!!!!!");
SerialUSB not working.txt
(81.77 KiB) Downloaded 15 times
Finally that I found I cannot use SerialUSB.begin(115200)
default SerialUSB 9600 without init will work .... not sure why
Post by stevestrong » Fri Oct 06, 2017 2:30 pm
I always use a delay of 1000 ms right at the beginning of setup, before calling Serial begin:
  delay(1000); // seems to be needed
  Serial.println("bla-bla");
Do you use the latest version from Roger's repo or my repo? My repo is a bit further advanced with respect to F4 development. Although in this regard it should not make any difference, there was no development in the USB direction lately.
Can you show us your sketch?
poiuycat
Post by poiuycat » Fri Oct 06, 2017 3:37 pm
stevestrong,
after few round of test and yes it work on you repo but not work on Roger's repo
thanks again. :lol:
