[libmaple] Generic F407VE mini (vcc-gnd version)
Post by stevestrong » Tue Nov 07, 2017 10:55 pm
A really small and powerful board, with some extra hardware and lots of pins.
http://wiki.stm32duino.com/index.php?ti ... 7VET6_Mini
The main difference compared to the generic black F4 board is that the mini board has a 25MHz crystal.
And the LED is on PB9 instead of PA6/7.
Important:
In order to get the board run, value 25 (instead of 8) must be entered here: https://github.com/stevstrong/Arduino_S ... cF4.c#L370
In Arduino IDE the Generic F407 series menu has to be selected.
Maybe we should add an additional selection item in Arduino menu the crystal frequency?
I just quickly tested LED blink (PB9), SPI 1 and 3 and all work.
UPDATE 20.11.3017
- added Wire lib to communicate with the on-board 24c08 Eeprom. (see: viewtopic.php?f=39&t=2804&p=37376#p37376)
Re: [libmaple] Generic F407VE mini (vcc-gnd version) is working
Post by RogerClark » Tue Nov 07, 2017 11:44 pm
Steve
I think we'd be better off with a new variant for this, or perhaps setup the build to allow this to be switched by a define from boards.txt
I think having to select the crystal freq each time, would be a pain. (though the IDE does remember the last setting)
Post by stevestrong » Wed Nov 08, 2017 1:28 pm
Ok, I will make a new entry in boards.txt for this, and define a new extra flag for the crystal frequency.
Post by RogerClark » Wed Nov 08, 2017 8:44 pm
thanks
Manny
Post by Manny » Wed Nov 08, 2017 11:24 pm
No wonder I was having trouble running this board.
Post by stevestrong » Sun Nov 12, 2017 2:34 pm
I finally managed to adapt boards.txt and platform.txt, included a new define CRYSTAL_FREQ.
With the same occasion I have reworked both txt files, moved the common parts from boards to platform.
This changes requested to change some of the F4 files, so I did that and some cleanup, too.
https://github.com/stevstrong/Arduino_S ... db35b57fd2
https://github.com/stevstrong/Arduino_S ... 888095d986
https://github.com/stevstrong/Arduino_S ... 5a94811edf
https://github.com/stevstrong/Arduino_S ... f84c4bb5cc
I have built all F4 targets, error-free.
Only the generic F4 series (black and mini) boards were tested, both work as expected.
Post by RogerClark » Sun Nov 12, 2017 6:59 pm
can you make a PR
Nutsy
Post by Nutsy » Mon Nov 13, 2017 11:36 pm
Ohh thanks for this :D ive been looking at these boards lately... Now i know theres some support going towards it. might be able to get them working :D
Post by stevestrong » Sun Nov 19, 2017 8:43 am
I have a problem with this board, the I2C 1 interface seems to get locked to BUSY state (SR2 bit 1) right after setting at least one of the PB6/7 pins to GPIO_AF_OUTPUT_OD.
I tried the software reset (SWRST), it clear the BUSY bit for the moment, but it gets set again after I release the SWRST bit.
I also tried the bus reset, no effect either, BUSY is set no matter what I try.
OTOH, software Wire implementation works, so the slave is definitively not blocking the bus.
Does anyone have a binary for this board with working I2C1 interface build with GENERIC or STM32duino core? i would like to investigate the signals at enable phase after reset.
I read several posts on internet and tried to implement every hint, but none of them helped.
I am trying to get desperate, it may be the interface faulty?
Post by RogerClark » Sun Nov 19, 2017 9:26 am
Steve,
Can you try STM's official core ? That would rule out a hardware fault in the silicon
