[libmaple] Generic F407VE mini (vcc-gnd version)
Re: [libmaple] Generic F407VE mini (vcc-gnd version)
Post by stevestrong » Sun Nov 19, 2017 9:43 am
Well, I don't know whether the official ST core has support for this board, this has 25MHz crystal.
I only found the Disco 407G the closest target supported.
EDIT
I checked the I2C part of ST official core , it does exactly the same as I do in the init phase.
Hmm.
It is really strange that the pins go low at once when I set the mode to GPIO_AF_OUTPUT_OD, and BUSY gets set.
Although I enable the I2C clock after the GPIOs are initialized, as recommended here: https://community.st.com/thread/43558-i ... ent-168570
Post by RogerClark » Sun Nov 19, 2017 7:17 pm
ummm
Sounds like a question for one of STMs own forums :-(
Post by stevestrong » Sun Nov 19, 2017 11:37 pm
OK, so it seems that it was me (as always :? )
I forgot to set the AF mode register correspondingly.
Funny, as soon as I set it right, it started to work... :mrgreen:
Post by RogerClark » Mon Nov 20, 2017 12:24 am
(LOL)
Such is programming
Post by stevestrong » Mon Nov 20, 2017 10:08 pm
I finally managed to bring Wire lib on F4 mini to work, the new files are checked in with this commit: https://github.com/stevstrong/Arduino_S ... 8d427d03f2
(Roger, don't ask me to prepare a PR, because I know now that I am not able to make a clean PR... :( .
Hopefully you can merge the files from the patch.)
The i2c.cpp and header files had to be amended, too.
I introduced a new parameter for Softwire: SOFT_HSPEED, which generates ~1MHz clock.
Additionally, I moved the "digitalPinTo..(pin)" defines from variant header files to gpio.h, because they are common for all variants.
EDIT
All (scanning) examples were tested and they work.
I attach an example file to handle the on-board Eeprom.
STM32F4_Eeprom_example.ino
(3.53 KiB) Downloaded 22 times
Post by RogerClark » Mon Nov 20, 2017 10:18 pm
I finally managed to bring Wire lib on F4 to work, the new files are checked in with this commit: https://github.com/stevstrong/Arduino_S ... 8d427d03f2
Thanks Steve
OK.
I'll try to manually merge this when I get time.
Post by RogerClark » Mon Nov 20, 2017 10:20 pm
Steve
Actually, if there is anything that needs to be manually merged, can you just raise and issue so I don't forget
I just raised and issue for this change
michael_l
Post by michael_l » Sun Jan 21, 2018 4:30 pm
Is this the correct place to report errors with Steve's repo?
I just downloaded Steve's libmaple master branch and tried simple led blink sketch with F407VE mini board. Didn't work so tried debugging with the new Atollic IDE and here's the result:
Here's the sketch:
  pinMode(LED_BUILTIN, OUTPUT);
  while(true) {
    digitalWrite(LED_BUILTIN, LOW);   // Turn the LED on (Note that LOW is the voltage level
    delay(300);                      // Wait for a second
    digitalWrite(LED_BUILTIN, HIGH);   // Turn the LED on (Note that LOW is the voltage level
Manny
Post by Manny » Sun Jan 21, 2018 7:46 pm
Got blink to work but not serial USB...did you chose the the right board?
michael_l
Post by michael_l » Sun Jan 21, 2018 7:52 pm
Yes, I chose the right board (mini) and serial USB from the Arduino menu. The wiki suggests to check pull-up for the usb pin if it doesn't enumerate. As we know It should be 1.5k. Have to check that next I guess.
