STM32-RFM69
kylix
Re: STM32-RFM69
Post by kylix » Wed Dec 13, 2017 7:43 pm
At the moment I'm trying to make this library work with STM32F401RE board: https://github.com/brainelectronics/RFM69-STM32
The original Lowpower Lab's library I'm only using with an Arduino compatible board and it works only on Arduino as it is (https://github.com/LowPowerLab/RFM69)
Re: STM32-RFM69
Post by stevestrong » Wed Dec 13, 2017 9:02 pm
Asking again: which core do you use? Arduino_STM32 or the STM32DUINO?
Re: STM32-RFM69
Post by fpiSTM » Wed Dec 13, 2017 9:09 pm
kylix wrote:
Sun Dec 03, 2017 7:55 pm
I've just updated the STM32 cores to the latest available version: 24.11.2017 (Arduino IDE v1.6.9) but I get this error while compiling:
I assume you use the STM core and you use the Nucleo F401. PA3 is used for Serial RX (via STLINK) so avoid to use it for attach interrupt.
By default your example (ino) set irqnum to 3. Even if it is a wrong name as it should be irqpin for attachinterrupt (as Steve already said several time).
https://github.com/brainelectronics/RFM ... 32.ino#L63
So attach interrupt is done on D3. For Nucleo F401, it is the PB3, //D3
So IRQ_PIN in the sketch should be set to PB3 instead of PA3.
https://github.com/brainelectronics/RFM ... 32.ino#L29
I think you have a misalignment with the pin.
kylix
Re: STM32-RFM69
Post by kylix » Wed Dec 13, 2017 9:53 pm
Yes, I've just checked and I confirm that in "Boards manager" (Arduino IDE) I have "STM32 Cores by ST-Microelectronics" installed.
I'll try to connect the IRQ PIN to PB3
THANKS!
PS: changed as it follows
#define IRQPIN     PB3
RFM69STM32 radio(CSPIN, IRQPIN, true, 3); (true is needed for RFM69HW module)
attachInterrupt(_interruptPin, RFM69STM32::isr0, RISING);
Connected RFM69's DI00 pin to D3 on F401RE board and now it hangs here (and I can't read the temperature from the RFM69 module anymore):
Transmitting at 433 Mhz...
Sending[0]:
It still...does something: it acts as a 433Mhz jammer now (I have some 433Mhz nodes that send sensor data to a Raspberry Pi gateway and since I connected this STM32 node, I don't get any data on the gateway :D )
kylix
Re: STM32-RFM69
Post by kylix » Sat Dec 23, 2017 11:26 am
Other suggestions?
