stm32duino core with System Workbench for bluepill
Re: stm32duino core with System Workbench for bluepill
Post by Rick Kimball » Mon Apr 17, 2017 1:20 pm
You probably want '-nostartfiles' instead of '-nostdlib'.
-nostartfiles lets you provide your own startup code but lets you link with the nano.specs libc stuff.
As far as code bloat goes, you need to spend some time with arm-none-eabi-objdump -CS yoursketch.ino.cpp.elf | less to see what is causing your code to bloat.
Post by ag123 » Mon Apr 17, 2017 2:24 pm
i'm thinking that it is possibly better to simply call init() prior to calling main() in start_c(), that would make the code more readable. But in the mean time that constructor 'black magic' works, hence, i'd guess we'd leave it, until it doesn't :D
gcc is interesting, with so many obscure/often ignored features in elf sections
http://www.cs.stevens.edu/~jschauma/810/elf.html
http://refspecs.linuxbase.org/LSB_3.0.0 ... tions.html
paksoft
Post by paksoft » Fri Nov 24, 2017 4:44 pm
I've tried to use Rick's bluepill.zip with AC6 in Windows 10 (64 bit), because setting up Linux is too difficult for me. I use blue pill and ST-Link from ebay.
I'm just newbie with eclipse software. I try to make several parameters adjustment and but finally, I've got error message. Does it look like fake ST-Link error?
Please give some suggestion.
pak
Post by Rick Kimball » Fri Nov 24, 2017 6:00 pm
You should probably create a new test project using System Workbench without using my project configuration. Verify that you can compile and debug on windows. It looks like you are specifying the wrong stlink device, based on the vid/pid mismatch.
VID/PID 0x0483 0x3748 for ST-Link/V2
VID/PID 0x0483 0x374b for ST-Link/V2-1
I setup the project expecting an stlink-v2 ... if you are using a "nucleo like" device you could change:
source [find interface/stlink-v2.cfg]
to
source [find interface/stlink-v2-1.cfg]
This was the openocd.cfg I used.
# An openocd config for the jc66_coreboard board with a single STM32F103C8Tx chip.
set WORKAREASIZE 0x4000
transport select hla_swd
source [find target/stm32f1x_stlink.cfg]
adapter_khz 950
# use software reset
reset_config none
Post by Rick Kimball » Fri Nov 24, 2017 6:32 pm
So I just upgraded my System Workbench. It seems the auto generated one now only actually works with stlink-v2-1 ...
# This is an bluepill board with a single STM32F103CBTx chip
# Generated by System Workbench for STM32
# Take care that such file, as generated, may be overridden without any early notice. Please have a look to debug launch configuration setup(s)
source [find interface/stlink.cfg]
set WORKAREASIZE 0x5000
transport select "hla_swd"
set CHIPNAME STM32F103CBTx
# Enable debug when in low power modes
set ENABLE_LOW_POWER 1
# Stop Watchdog counters when halt
set STOP_WATCHDOG 1
# STlink Debug clock frequency
set CLOCK_FREQ 4000
# use hardware reset, connect under reset
# connect_assert_srst needed if low power mode application running (WFI...)
reset_config srst_only srst_nogate connect_assert_srst
set CONNECT_UNDER_RESET 1
source [find target/stm32f1x.cfg]
Searching in my Ac6 directory I find stlink.cfg .. has this:
$ find . -iname 'stlink.cfg'
./SystemWorkbench/plugins/fr.ac6.mcu.debug_2.1.3.201710251246/resources/openocd/st_scripts/interface/stlink.cfg
$ vi $(find . -iname 'stlink.cfg')
# STMicroelectronics ST-LINK in-circuit debugger/programmer
interface hla
hla_layout stlink
hla_device_desc "ST-LINK/V2-1"
hla_vid_pid 0x0483 0x374b
You are going to have to use a custom openocd.cfg file you can't use the auto generated one any more.
Note: It is a constant struggle to keep things working that once worked. Vendors upgrade their "features" and usually the people who are doing the changes don't care about maintaining things working with previous versions. ... I think Raul Julia got them started on this path:
https://www.youtube.com/watch?v=AjGXn249Fc0
Post by Rick Kimball » Fri Nov 24, 2017 7:45 pm
Since I last looked it seems they have added a new feature, the st-link server. It appears to offer access to both the debug interface along with the Serial Wire Viewer (SWV) monitoring port.
https://my.st.com/content/my_st_com/en/ ... erver.html
You might want to check that out.
paksoft
Post by paksoft » Sat Nov 25, 2017 6:54 pm
@Rick
I created new project with the code generated by STMCubeMx.
It works, now I need to replace CMSIS with stm32duino core. Could you please give some guidelines for porting stm32duino core?
pak
AC6_WS - Debug - Blink_BluePill_HAL_Driver_Src_stm32f1xx_hal_gpio.c - Eclipse.jpg
AC6_WS - Debug - Blink_BluePill_HAL_Driver_Src_stm32f1xx_hal_gpio.c - Eclipse.jpg (183.09 KiB) Viewed 174 times
