STM32f103xx External Interrupt using register - not working
Phoenix
Post by Phoenix »
Hi everyone,
I am using STM32F103C8 blue pill board with arduino ide - stm32duino official core.
I am trying to configure the external interrupt on pin PB4, according to the datasheet.
However, seems like i have missed something or it doesn't work at all.
This is the piece of code I am using for testing purposes.
  pinMode(PB4, INPUT_PULLDOWN);
  RCC->APB2ENR |= (1 << 0);
  AFIO->EXTICR[2] |= (1 << 0);
  EXTI->IMR |= (1 << 4);
  EXTI->RTSR |= (1 << 4);
  EXTI->FTSR &= ~(1 << 4);
  NVIC_SetPriority(EXTI4_IRQn, 0);
  NVIC_EnableIRQ(EXTI4_IRQn);
void EXTI4_IRQHandler(void) {
  Serial.println("Trigger_Signal");
if i use
attachInterrupt(PB4, EXTI4_IRQHandler, RISING);
, everything works but I can't get it to work through register manipulation.
Any Idea on how to do so?
Regards,
Re: STM32f103xx External Interrupt using register - not working
you need to unmask the line?
Phoenix
Post by Phoenix »
dannyf wrote: Fri Mar 24, 2023 11:11 pm you need to unmask the line?
This line:
does the unmasking.
Answers: 91
EXTI4_IRQHandler is alread defined by the core interrupt part
https://github.com/stm32duino/Arduino_C ... t.cpp#L371
So if you want use it you have to disabled it by defining: HAL_EXTI_MODULE_DISABLED
https://github.com/stm32duino/Arduino_C ... figuration
You can use build_opt.h feature to do that:
https://github.com/stm32duino/Arduino_C ... uild_opt.h
with
-DHAL_EXTI_MODULE_DISABLED
Finally, you have to declare the handler as extern "C":
extern "C" void EXTI4_IRQHandler(void) {
Phoenix
Post by Phoenix »
fpiSTM wrote: Sat Mar 25, 2023 6:46 am EXTI4_IRQHandler is alread defined by the core interrupt part
with
Well, when i compile the sketch with extern "C", i get the following error:
exit status 1
Compilation error: conflicting declaration of 'void EXTI4_IRQHandler()' with 'C' linkage
Answers: 91
Maybe a cache issue linked to arduino IDE. I got several with new version 2.x
Phoenix
Post by Phoenix »
fpiSTM wrote: Sat Mar 25, 2023 9:39 am Maybe a cache issue linked to arduino IDE. I got several with new version 2.x
So, how do we slove this issue?
What is the correct way of using external interrupt through register manipulation?
And how to use the build_opt.h file correctly?
Do I create header file called "build_opt" because arduino ide only accepts .h, .c, .cpp, .ino.
and then put this line in it
and then drop that in the sketechbook folder directory which is located on C:\Users\"PC-USER"\Documents\Arduino
Am I configuring the registers correctly?
Answers: 91
Simply create build_opt.h file and add -D..... inside. About register Ididn't check.
