Enabling parallel build in Eclipse to speed up compilation
Post by victor_pv » Sun Jul 02, 2017 9:41 pm
Today I was wondering why when I compile it's so slow and doesn't use either much of my CPU or Disk throughput.
A search in Google took me to this page, showing how to enable parallel builds in Eclipse (including the Arduino plugin/Sloeber):
http://infocenter.arm.com/help/index.js ... 15608.html
I did a test enabling it to the "optimal" job number (in my case 8, which matches the number of threads in this CPU).
With the setting disabled, compiling Marlin:
16:35:46 Build Finished (took 2m:37s.812ms)
With that setting enabled and set to 8:
16:37:38 Build Finished (took 18s.996ms)
I ran it several times to confirms it had nothing to do with the files being cached or something like it.
Re: Enabling parallel build in Eclipse to speed up compilation
Post by Pito » Mon Jul 03, 2017 7:47 am
I've tried it (use 4 parallel jobs here, 2 cores, 4 threads) and the speed up is close to 2x.. (clean->build) 8-)
@Victor: any idea how to speed up the indexing at the start of the Sloeber? With 30+ projects it takes a minute, all 4 threads full load..
danieleff
Post by danieleff » Mon Jul 03, 2017 7:56 am
Close the unused projects ;)
Post by Pito » Mon Jul 03, 2017 8:54 am
+1 :)
It still takes 8 seconds with 2 small projects out of 37 :)
