Debug STM32 with VScode
caniggia
Re: Debug STM32 with VScode
Post by caniggia » Fri Aug 18, 2017 12:00 pm
@stuartw
I would prefer it if I could see compiler output, however it is probably hidden somewhere.
Add to "arduino.json" this line:
"output": "build",
and you will get all compiled files in subfolder named "build".
BR
caniggia
vitor_boss
Post by vitor_boss » Thu Aug 24, 2017 12:49 am
Where that config could be found?
            "miDebuggerPath": "/usr/bin/arm-none-eabi-gdb",
            "debugServerPath": "/usr/bin/openocd",
            "debugServerArgs": "-f interface/stlink-v2.cfg -f target/stm32f1x.cfg",
EDIT:
Last opencd is here https://sourceforge.net/projects/openocd/?source=navbar
Last gdb is at http://ftp.gnu.org/gnu/gdb/
vitor_boss
Post by vitor_boss » Thu Aug 24, 2017 2:16 pm
I have entered those values and don't work:
            "miDebuggerPath": "D:/VScode/arm-none-eabi-gdb",
            "debugServerPath": "D:/VScode/openocd",
            "debugServerArgs": "-f interface/stlink-v2.cfg -f target/stm32f4x.cfg",
Any help are very welcome, I'm trying to debug the code for a week now
Edit: this is my device path "USB\VID_0483&PID_3748\6&1EC10D3F&0&1" I had updated it with last firmware
vitor_boss
Post by vitor_boss » Sat Aug 26, 2017 6:17 pm
Guys, I really need help here, when I try to start debugger give error "Unable to start debugging. Nenhum processo associado a este objeto."
What I'm doing wrong?
STM32 ST-LINK works fine, but upload via st-link don't work
vitor_boss
Post by vitor_boss » Wed Aug 30, 2017 1:50 am
iamseer wrote:
Wed Jul 19, 2017 7:58 pm
Happy debugging!
Maybe I missed something, I follow all the steps and cant get it running.
Could you help?
caniggia
Post by caniggia » Wed Aug 30, 2017 9:48 am
@vitor_boss
How i did it on Windows 10.
Tested with ST-Link & Bluepill.
1.) Download and install "Arduino":
https://www.arduino.cc/en/Main/Software
2.) In Arduino "Boards Manager" install "Arduino SAMD Boards", not "Ardiuno SAM Boards"!!!
3.) Download rogerclarkmelbourne's repo:
Put folder from zip to:
C:\Users\<username>\Documents\Arduino\hardware
and rename it to "Arduino_STM32" !!!
4.) In Arduino Try to compile & upload blink example
5.) Download and install "Visual Studio Code"
https://code.visualstudio.com/download
6.) Download and instal "Visual Studio Code extension for Arduino" v0.2.5 !!!
https://marketplace.visualstudio.com/it ... de-arduino
It will also install "C/C++ for Visual Studio Code"
7.) You don't need to set/change anything in "launch.json"
8.) Set the project in VSCODE for blink example and try to compile(ctrl+alt+r), upload(ctrl+alt+u) and debug(F5).
BR
caniggia
vitor_boss
Post by vitor_boss » Wed Aug 30, 2017 11:11 am
@vitor_boss
BR
caniggia
Only work with F1? My board is F407VE. And how include another library like STM32GENERIC?
And_Ru
Post by And_Ru » Sun Sep 03, 2017 10:14 pm
@vitor_boss
I tried to do all this, but the program ask me to choose board and I cannot see genericSTM32 in the list. What should I choose?
caniggia
Post by caniggia » Mon Sep 04, 2017 7:04 am
@And_Ru
Press F1 and type "arduino" and you will get all the Arduino commands:
  • Arduino: Board Manager: Manage packages for boards. You can add 3rd party Arduino board by configuring Additional Board Manager URLs in board manager.
  • Arduino: Change Baud Rate: Change the baud rate of selected serial port.
  • Arduino: Change Board Type: Change board type or platform.
  • Arduino: Close Serial Monitor: Stop serial monitor and release the serial port.
  • Arduino: Examples: Show example list.
  • Arduino: Initialize: Scaffold a VS Code project with an Arduino sketch.
  • Arduino: Library Manager: Explore and manage libraries.
  • Arduino: Open Serial Monitor: Open serial monitor in the intergrated output window.
  • Arduino: Select Serial Port: Change the current serial port.
  • Arduino: Send Text to Serial Port: Send a line of text via the current serial port.
  • Arduino: Upload: Build sketch and upload to Arduino board.
  • Arduino: Verify: Build sketch.
Please, read this page "Visual Studio Code extension for Arduino":
BR
caniggia
otw
Post by otw » Wed Dec 06, 2017 10:35 pm
Hello,
Im trying to run STM32F4 Discovery board.
I came across a couple issues:
Regarding copying scripts and executing the instruction inside the termian, after doing so Im getting different result, much longer result.
Cant find "misc/usbmapping.json".
I tried to add following path: "-f interface/stlink-v2.cfg -f target/stm32f4x.cfg" into "debugServerArgs".
After hit debug I get an Error that "arm-none-eabi-gdb is not signed".
Im running Mac os high sierra
I appreciate every help,
Regards!
EDIT:
I finally managed to debug my project.
I installed openocd and gcc-arm-none-eabi using Homebrew.
Then I set up parameters inside launch.json file:
            "miDebuggerPath": "/usr/local/Cellar/gcc-arm-none-eabi/20160928/bin/arm-none-eabi-gdb",
            "debugServerPath": "/usr/local/Cellar/open-ocd/0.10.0/bin/openocd",
Insure to type proper version/revision/date inside mentioned above paths.
