[SOLVED] Problems with the compiler after installing stm32 core
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Mon Dec 04, 2017 1:15 pm
Hello friends,
A very strange thing happens to me. after installing stm32 core in the
arduino ide, I select a project that worked correctly for Mega 2650
compiles it without errors and I transfer it to the mega, but what is programmed does not work well.
If I take the direct Hex file that I had saved a copy without modifying it by the compiler and I transfer it to the mega that copy if it works correctly.
The same compiled and transferred program does not work well.
I do not know what may have changed after installing the stm32 core.
Maybe a reference to some bookstore ..
Does anyone have any ideas or has it happened to him?
I searched the forum and on the internet and I do not find anything related.
I have the latest version of the arduino ide
Greetings and thank you.
Last edited by FRANCISCOGIMENO on Mon Dec 04, 2017 10:19 pm, edited 1 time in total.
zoomx
Re: Problems with the compiler after installing stm32 core
Post by zoomx » Mon Dec 04, 2017 2:38 pm
I believe that it is a library problem. Set the IDE on verbose and check which library are used.
FRANCISCOGIMENO
Post by FRANCISCOGIMENO » Mon Dec 04, 2017 10:18 pm
Ok thanks to the end her a library that I had to reinstall.
But I do not know why it has been modified because I have not touched it. but good and this one.
Thanks for everything.
