[SOLVED] Sloeber and float sprintf: doesn't work
Re: Sloeber and float sprintf: doesn't work
Post by Pito » Fri Dec 08, 2017 12:15 pm
Combiner recipe in platform.txt (it adds the {compiler.combine.flags} into the build):
## Combine gc-sections, archives, and objects
recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {compiler.c.elf.flags} -mcpu={build.mcu} "-T{build.variant.path}/{build.ldscript}" "-Wl,-Map,{build.path}/{build.project_name}.map" {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" "-L{build.path}" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group {compiler.combine.flags} {object_files} "{build.path}/{archive_file}" -Wl,--end-group
While building you have to see the -u stuff (see below), otherwise the _sbrk and friends will not be linked in, and therefore the malloc() and friends will not work, and therefore the sprintf and friends will not work either..
'Starting combiner'
"C:\Program_Files\sloeber\/arduinoPlugin/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections -mcpu=cortex-m3 "-TC:/Users/xxx/MyCode/Arduino/hardware/Arduino_STM32/STM32RG1/STM32F1/variants/generic_stm32f103c/ld/bootloader_20.ld" "-Wl,-Map,C:\Users\xxx\MyCode\Sloeber\Test_sprintf/Release/Test_sprintf.map" "-LC:/Users/xxx/MyCode/Arduino/hardware/Arduino_STM32/STM32RG1/STM32F1/variants/generic_stm32f103c/ld" -o "C:\Users\xxx\MyCode\Sloeber\Test_sprintf/Release/Test_sprintf.elf" "-LC:\Users\xxx\MyCode\Sloeber\Test_sprintf/Release" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group -u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid    .\.ino.cpp.o   C:\Users\xxx\MyCode\Sloeber\Test_sprintf\Release\arduino.ar    C:/Users/xxx/MyCode/Sloeber/Test_sprintf/Release/arduino.ar  -Wl,--end-group
'Finished building: Test_sprintf.elf'
I use Sloeber4.0 under Win7, works fine. These issues are not Eclipse or Sloeber related but an Arduino heritage..
luca_stm32
Post by luca_stm32 » Fri Dec 08, 2017 7:25 pm
Hi Pito.
Thanks for suggestions.
In file platform.txt that is under /home/luca/arduino/hardware/Arduino_STM32-master/STM32F1/platform.txt I added:
name=STM32 Boards (STM32duino.com)
version=0.1.2
compiler.warning_flags=-w -DDEBUG_LEVEL=DEBUG_NONE
compiler.warning_flags.none=-w -DDEBUG_LEVEL=DEBUG_NONE
compiler.warning_flags.default=-DDEBUG_LEVEL=DEBUG_NONE
compiler.warning_flags.more=-Wall -DDEBUG_LEVEL=DEBUG_FAULT
compiler.warning_flags.all=-Wall -Wextra -DDEBUG_LEVEL=DEBUG_ALL
compiler.combine.flags=-u _sbrk -u link -u _close -u _fstat -u _isatty -u _lseek -u _read -u _write -u _exit -u kill -u _getpid
and
#recipe.c.combine.pattern="{compiler.path}{compiler.c.elf.cmd}" {compiler.c.elf.flags} -mcpu={build.mcu} "-T{build.variant.path}/{build.ldscript}" "-Wl,-Map,{build.path}/{build.project_name}.map" {compiler.c.elf.extra_flags} -o "{build.path}/{build.project_name}.elf" "-L{build.path}" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group {object_files} "{build.path}/{archive_file}" -Wl,--end-group
I restarted soeber to load changes but in sloeber console I can't still see added directives:
Starting combiner
"/home/luca/sloeber//arduinoPlugin/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-g++" -Og -Wl,--gc-sections -mcpu=cortex-m3 "-T/home/luca/arduino/hardware/Arduino_STM32-master/STM32F1/variants/generic_stm32f103c/ld/jtag_c8.ld" "-Wl,-Map,/home/luca/Documenti/sloeber-workspace/Sprintf_Test/Release/Sprintf_Test.map" "-L/home/luca/arduino/hardware/Arduino_STM32-master/STM32F1/variants/generic_stm32f103c/ld" -o "/home/luca/Documenti/sloeber-workspace/Sprintf_Test/Release/Sprintf_Test.elf" "-L/home/luca/Documenti/sloeber-workspace/Sprintf_Test/Release" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group    ./sloeber.ino.cpp.o    /home/luca/Documenti/sloeber-workspace/Sprintf_Test/Release/arduino.ar  -Wl,--end-group
/home/luca/sloeber/arduinoPlugin/packages/arduino/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/../lib/gcc/arm-none-eabi/4.8.3/../../../../arm-none-eabi/lib/armv7-m/libnosys.a(sbrk.o): In function `_sbrk':
sbrk.c:(.text._sbrk+0x30): warning: undefined reference to `end'
Finished building: Sprintf_Test.elf
I will investigate.
I'm using Soleber 4.2 and Linux 64 bit
Thanks again
Regards.
Luca.
Post by victor_pv » Fri Dec 08, 2017 8:21 pm
In the project properties, change the board to something else, apply, and then back to the one you were using. That will reload all flags from platform.txt
Not sure if it reloads them by just closing and opening, I believe it doesn't.
I use sloeber 4.1 in a windows 10 and 4.0 in Win 8.1, both work fine.
Post by stevestrong » Fri Dec 08, 2017 8:46 pm
luca, which upload method do you use?
I think the linker file is not the right one. Instead of jtag_c8.ld it should be bootloader_20.ld.
luca_stm32
Post by luca_stm32 » Sat Dec 09, 2017 9:58 am
@Victor
I followed your instructions and now added directives are loaded correclty and sketch works as aspected also under Sloeber :D
@Steve
I use STLink programmer. I think jtag_c8.ld in this case is correct.
@Victor, Steve, Pito and Roger
Thanks again for your support :D
@Roger
Could be possible adding this directives in platform.txt by default? I tested this sketch with modified platform.txt and Arduino IDE and works, but I don't know if the added directives have some sort of collateral effect.
I belive I'm not the first one asking you this thing. I also know that under Arduino IDE STM32 core works correctly and core STM32 is intended for Arduino IDE.
Otherwise, is there another method to make it be "compatible" with eclipse IDE?
What I'm trying to tell is that if someone want to use STM32 core from repository and use Eclipse, functions like new(), sprintf... doesn't work and they don't know why.
Thanks again and compliments again for your work.
Regards.
Luca.
Post by Pito » Sat Dec 09, 2017 10:44 am
In Sloeber, in order to load new properties and settings, you have to go:
Project -> Properties -> Arduino -> Apply -> OK.
