STM acquires Atollic
Re: STM acquires Atollic
Post by stevestrong » Thu Jan 18, 2018 6:02 pm
Just installed V9.0.0 and got an Atollic-titled Eclipse :)
Post by zmemw16 » Thu Jan 18, 2018 10:10 pm
have a look inside your <home> dot eclipse directory if using linux or equivalent
i was looking to see if i needed to back it up, as i've had eclipse based programs clobber it or at least appear to.
one of my reasons for rebuilding arduino with a version specific naming for dot slash dot arduino15 dir
also installing to <home> installs in <home>/opt, not quite what i was expecting
paksoft
Post by paksoft » Sat Jan 20, 2018 7:23 am
Is Atollic IDE support C++ core like STM32 core?
Have anyone used STM32 core in Atollic IDE?
pak
Post by fpiSTM » Sat Jan 20, 2018 8:49 am
Just a tips: you can create a "portable" folder in the root folder of Arduino IDE to make it standalone. All user files will go in this directory. useful for several Arduino installations to avoid using the same user folder in <user local>/.arduino15
Post by zmemw16 » Sat Jan 20, 2018 12:20 pm
@fpiSTM
my only user is stephen, so portable is not likely to assist me.
i have or did have multiple ide versions installed, 1.8.1 1.8.2 etc, they each use(used) $(HOME) slash dot arduino15 etc
my installation(s) is in my home directory, i do do root, but not a lot :o
it's a change in two lines and the only one i do.
i was mithering on about assorted eclipse based products that used dot eclipse in a similar fashion mangling everything installed and that i've finally noticed it now creates sub-dir's for different products or maybe the people writing said products noticed that issue.
Post by dannyf » Sun Jan 21, 2018 12:07 am
I would suspect that post the acquisition it's support for non-st chips would be limited. So maybe time to download a copy now.
9.0 supports only STM chips now. Also it will include SPL by default. Didn't see any option to select which modules of the SPL to be included in.
CoIDE was superb in that department. Too bad they died a tragic death.
Post by dannyf » Sun Jan 21, 2018 12:08 am
are older versions of Atollic still available for download?
