IDE with Eclipse with Jantje's plugin
Re: IDE with Eclipse with Jantje's plugin
Post by stevestrong » Fri Apr 07, 2017 4:13 pm
Guys, just a short question: how do you "step"? With F5 in the assembler window?
In my case, the pointer always jumps two instructions at once instead of one...
Post by Pito » Fri Apr 07, 2017 5:43 pm
From left:
Run till breakpoint, or continuous run
Stop (when running)
Terminate process
Disconnect
Step into F5 - jumps into the function (C source window)
Step over F6 - jumps over the function (C source window)
Step return F7 - return when you are stepping somewhere deep in a function (C source window)
Instruction stepping mode - when active (click on it) - you steps with F5 through assembler instructions (disassembler window)
From right:
Reset and run (stops at main)
FYI - a lot of interesting stuff for hobby users of Eclipse IDE and arm (and much more):
https://mcuoneclipse.com/compendium/#Eclipse%20IDE
Post by stevestrong » Fri Apr 07, 2017 7:04 pm
As I wrote, in the disassembly window with F5 the instruction pointer always jumps 2 lines/instructions instead of one instruction line.
What can be the problem?
Post by ag123 » Fri Apr 07, 2017 8:12 pm
i did an experiment, it seemed gdb is following the c expression rather than stepping assembly (this debug is done in qemu - emulated)
in this case the instruction hops from the previous movs to the next
there are other cases it seemed gcc is too 'smart' and optimise away some codes and debug skips the c instructions altogether if it isn't referenced
found a web about gdb it seemed stepi command may do that, but i'm not sure how to do that in eclipse
http://mohit.io/blog/gdb-assembly-langu ... gging-101/
Post by ag123 » Fri Apr 07, 2017 8:29 pm
found it, click that icon shown and after that clicking step or F5 goes into instruction stepping mode
Post by stevestrong » Fri Apr 07, 2017 10:07 pm
Ok, thanks, i will try it.
Post by stevestrong » Sat Apr 08, 2017 8:44 am
Yepp, I confirm: it works.
Post by zmemw16 » Sat Apr 08, 2017 9:05 pm
for me at least that has to be the understatement of 2017 so far :lol:
can you overdose on eclipse?
Post by ag123 » Sun Apr 09, 2017 9:32 am
oh btw i succeeded in compling Arduino_STM32 - STM32F1 branch with gnu arm eclipse, but my blinky sketch is a whopping 54k in size, need to figure out what accounts for all that bloat. it runs though :lol:
Post by Pito » Sun Apr 09, 2017 12:07 pm
Blink example here in Sloeber is 12kB bin:
C:/Users/pito/MyCode/Sloeber/Blink/Release/Blink.elf  :
section             size        addr
.text               8648   134217728
.ARM.exidx             8   134226376
.data               1896   536870912
.rodata             1516   134228280
.bss                 264   536872808
.debug_aranges      2896           0
.debug_info        88779           0
.debug_abbrev      17731           0
.debug_line        29199           0
.debug_frame        6720           0
.debug_str         23839           0
.debug_loc         26250           0
.ARM.attributes       41           0
.debug_ranges       4680           0
.comment             112           0
Total             212579
'Finished building target: Blink'
