IDE with Eclipse with Jantje's plugin
Re: IDE with Eclipse with Jantje's plugin
Post by Pito » Wed Apr 12, 2017 10:15 am
Then everything is ok and it should work with the bootloader. But it does not work here :)
It seems to me the eabi-gdb gives a command to the jlink to flash from 8000000 even it should be from 8002000 for the bootloader variant.
PS: I've done following experiment in Sloeber:
1. I compile Blink with MMini Bootloader20 profile (compiles from 8002000) and flash it via Jflash. Bootloader stops working. The blink does not blink.
2. I flash the bootloader via Jflash from 8000000. The Bootloader lives and blink blinks.
So what went wrong here?
michael_l
Post by michael_l » Wed Apr 12, 2017 10:53 am
In GBD when issuing a 'load abc.elf' command to flash image does it look from inside .elf file where to flash the file (e.g. 0x8002000 or 0x8005000) ?
EDIT: ELF shows start address for VMA (virtual memory address) and LMA (load memory address) 0x8002000
c:.pioenvs\genericSTM32F103CB\firmware.elf
architecture: arm, flags 0x00000112:
EXEC_P, HAS_SYMS, D_PAGED
start address 0x08007b4d
Program Header:
0x70000001 off    0x00016288 vaddr 0x08016288 paddr 0x08016288 align 2**2
         filesz 0x00000008 memsz 0x00000008 flags r--
    LOAD off    0x00000000 vaddr 0x08000000 paddr 0x08000000 align 2**15
         filesz 0x00016284 memsz 0x00016288 flags rwx
    LOAD off    0x00016288 vaddr 0x08016288 paddr 0x08016288 align 2**15
    LOAD off    0x00018000 vaddr 0x20000000 paddr 0x08016290 align 2**15
         filesz 0x00000ce8 memsz 0x00000ce8 flags rw-
    LOAD off    0x0001ef78 vaddr 0x08016f78 paddr 0x08016f78 align 2**15
         filesz 0x00000ec4 memsz 0x00000ec4 flags r--
    LOAD off    0x00020ce8 vaddr 0x20000ce8 paddr 0x20000ce8 align 2**15
         filesz 0x00000000 memsz 0x000036e8 flags rw-
private flags = 5000002: [Version5 EABI] [has entry point]
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .text         00014284 08002000  08002000 00002000  2**4
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
  1 .text.align   00000004  08016284  08016284  00016284  2**0
                  ALLOC, CODE
  2 .ARM.exidx    00000008  08016288  08016288  00016288  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, DATA
  3 .data         00000ce8  20000000  08016290  00018000  2**3
                  CONTENTS, ALLOC, LOAD, DATA
  4 .rodata       00000ec4  08016f78  08016f78  0001ef78  2**3
  5 .bss          000036e8  20000ce8  20000ce8  00020ce8  2**2
                  ALLOC
  6 .debug_aranges 00002178  00000000  00000000  0001fe40  2**3
                  CONTENTS, READONLY, DEBUGGING
  7 .debug_info   0007657c  00000000  00000000  00021fb8  2**0
  8 .debug_abbrev 0000c7a5  00000000  00000000  00098534  2**0
  9 .debug_line   00016687  00000000  00000000  000a4cd9  2**0
 10 .debug_frame  0000637c  00000000  00000000  000bb360  2**2
 11 .debug_str    00015bff  00000000  00000000  000c16dc  2**0
 12 .debug_loc    0002a6c2  00000000  00000000  000d72db  2**0
 13 .ARM.attributes 00000029  00000000  00000000  0010199d  2**0
                  CONTENTS, READONLY
 14 .debug_ranges 00002d48  00000000  00000000  001019c6  2**0
 15 .comment      00000070  00000000  00000000  0010470e  2**0
                  CONTENTS, READONLY
SYMBOL TABLE:
08002000 l    d  .text  00000000 .text
08016284 l    d  .text.align    00000000 .text.align
Post by Pito » Wed Apr 12, 2017 11:32 am
.elf shows to 8002000.
My next observation (Sloeber) with bootloader20 ld profile:
1. Now (debug profile) I can compile, upload and debug the blink in the debugger. I can step through the code and asm. With "Executable offset" 08002000 set in debug config. No other settings in ld scripts or elsewhere.
2. When I try to run off the debugger (Jlink disconnected), the bootloader lives, the blink led lits but not blinks, and Win tells me there is a problem with USB port (the MMini one).
3. When I plug the usb off the MMini, and power MM from outside, the bootloader lives and the blink starts and blinks ok.
4. When I plug the usb back into MMini after a few minutes, the bootloader lives and blink blinks. The automatic upload from Sloeber via USB works as well.
Post by Pito » Wed Apr 12, 2017 11:42 am
It could be the Debugger inserts the BreakPoints into the flash, thus the BPoints interfere with the code execution (especially around USB)..
Post by ag123 » Wed Apr 12, 2017 11:43 am
looks like u've solved it :D
i do note that it seem necessary to power cycle the MMini after disconnecting debug
it'd seem reset isn't sufficient
i've a different issue though, at times my stlinkv2 simply won't connect, but on my end it seem like a hardware / connectivity issue
michael_l
Post by michael_l » Wed Apr 12, 2017 1:13 pm
Personally I'll be using platformio with Eclipse or Ozone. After small modification it builds new image really efficiently. Since platformio works and builds images I don't see any benefit with Arduino plugin except for serial monitor that you can start from toolbar.
Post by Rick Kimball » Wed Apr 12, 2017 1:56 pm
You can install the a serial terminal feature as part of eclipse.
https://mcuoneclipse.com/2015/04/20/ser ... ipse-luna/
Post by stevestrong » Wed Apr 12, 2017 2:29 pm
I tried to follow the steps, but, although installation seems to be successful, the USB serial Rx does not work somehow, no data is received...
Post by Rick Kimball » Wed Apr 12, 2017 2:33 pm
To be honest I use putty. :) .. I had seen that a while back but never tried it.
More info here: https://mcuoneclipse.com/2015/04/20/ser ... ipse-luna/
It appears to have an issue.
Post by stevestrong » Wed Apr 12, 2017 2:45 pm
well, after several restarts it seems that Rx works. But how to send data?
