Platformio
pirimmsr
Re: Platformio
Post by pirimmsr » Sat Dec 03, 2016 12:24 am
I got the blink.ino example working on the BluePill board under Win8 with the following platformio.ini settings:
[env:bluepill_f103c8]
platform = ststm32
board = bluepill_f103c8
framework = arduino
upload_port = COM10
upload_protocol = serial
Needed to change the LED from PB1 to PC13 as follows
#define BOARD_LED PC13
  // initialize digital pin PB1 as an output.
  pinMode(BOARD_LED, OUTPUT);
Kenjutsu helped me get going with his statement about 57600 baud. I had to change line 11 in C:\Users\{user}\.platformio\packages\tool-stm32duino\serial_upload.bat FROM:
stm32flash -g 0x8000000 -b 230400 -w %str% %1
TO:
stm32flash -g 0x8000000 -b 57600 -w %str% %1
michael_l
Re: Platformio
Post by michael_l » Tue Dec 06, 2016 1:17 pm
If you want to use SPI, you'll have to add
lib_deps=SPI
for platformio to find SPI libs.
platform = ststm32
framework = arduino
[color=#BF0000]lib_deps = SPI[/color]
[platformio]
src_dir=.
michael_l
Re: Platformio
Post by michael_l » Tue Mar 28, 2017 5:01 pm
Has anybody got UPLOAD_MODE=dfu working with platformio so that the actual code and USB works ?
I can build and upload (dfu) with platformio but after flashing there's no COM port.
Compiling with Arduino IDE is quite time-consuming especially with old laptops so it would be so great to get platformio working.
Any hints where to start looking ?
martinayotte
Re: Platformio
Post by martinayotte » Tue Mar 28, 2017 5:26 pm
In your compile flags, do you have the "-DSERIAL_USB" defined ?
michael_l
Re: Platformio (solved)
Post by michael_l » Tue Mar 28, 2017 6:29 pm
I'm actually flashing to BluePill but using genericSTM32F103CB because it has 128kB defined in platformio config. Is this a problem ?
according to build log
log.zip
(4.63 KiB) Downloaded 13 times
there is -DSERIAL_USB
here's one row from build process:
arm-none-eabi-g++ -o .pioenvs\genericSTM32F103CB\lib\SdFat\FatLib\FatFilePrint.o -c -fno-rtti -fno-exceptions -g -Os -ff
unction-sections -fdata-sections -Wall -mthumb -nostdlib -mcpu=cortex-m3 --param max-inline-insns-single=500 -march=armv
7-m -DF_CPU=72000000L -DGENERIC_STM32F103C -DPLATFORMIO=30300 -DARDUINO_GENERIC_STM32F103C -DMCU_STM32F103CB -DARDUINO=1
0610 -DBOARD_generic_stm32f103c -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -DDEBUG_LEVEL=DEBUG_NONE -D__STM32F1__ -DARDUIN
O_ARCH_STM32F1 -DVECT_TAB_ADDR=134225920 -DSERIAL_USB -DGENERIC_BOOTLOADER -IC:\Users\michael\.platformio\packages\framewor
k-arduinoststm32\STM32F1\cores\maple -IC:\Users\michael\.platformio\packages\framework-arduinoststm32\STM32F1\system\libmap
le -IC:\Users\michael\.platformio\packages\framework-arduinoststm32\STM32F1\system\libmaple\include -IC:\Users\michael\.platfo
rmio\packages\framework-arduinoststm32\STM32F1\system\libmaple\usb\stm32f1 -IC:\Users\michael\.platformio\packages\framewor
k-arduinoststm32\STM32F1\system\libmaple\usb\usb_lib -IC:\Users\michael\.platformio\packages\framework-arduinoststm32\STM32
F1\variants\generic_stm32f103c -IC:\Users\michael\.platformio\packages\framework-arduinoststm32\STM32F1\libraries\SPI\src -
IC:\Users\michael\.platformio\packages\framework-arduinoststm32\STM32F1\libraries\SdFat\src C:\Users\michael\.platformio\packa
ges\framework-arduinoststm32\STM32F1\libraries\SdFat\src\FatLib\FatFilePrint.cpp
One difference I found is that Arduino build uses -Og and platformio uses -Os flag for optimization
EDIT:
Further studying.. there seems to be more difference in linking phase:
This is from platformio:
arm-none-eabi-g++ -o .pioenvs\genericSTM32F103CB\firmware.elf -Os -Wl,--gc-sections,--relax -mthumb -mcpu=cortex-m3 -Wl,-T"jtag.ld" .pioenvs\genericSTM32F103CB\src\BPCB.ino.o -LC:\Users\michael\.platformio\platforms\ststm32\ldscripts -LC:\Users\michael\.platformio\packages\framework-arduinoststm32\STM32F1\variants\generic_stm32f103c\ld -L.pioenvs\genericSTM32F103CB -Wl,--start-group .pioenvs\genericSTM32F103CB\libFrameworkArduinoVariant.a .pioenvs\genericSTM32F103CB\libFrameworkArduino.a -lc -lgcc -lm -lstdc++ -lnosys -lc .pioenvs\genericSTM32F103CB\lib\libFreeRTOS821.a .pioenvs\genericSTM32F103CB\lib\libSPI.a .pioenvs\genericSTM32F103CB\lib\libArduinoJson_ID64.a .pioenvs\genericSTM32F103CB\lib\libSdFat.a -Wl,--end-group
This is from Arduino IDE:
"C:\Users\michael\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -Og -Wl,--gc-sections -mcpu=cortex-m3 "-TC:\Users\michael\Documents\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c/ld/bootloader_20.ld" "-Wl,-Map,C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp/BPCB.ino.map" "-LC:\Users\michael\Documents\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c/ld" -o "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp/BPCB.ino.elf" "-LC:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\sketch\BPCB.ino.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\MapleFreeRTOS821.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\croutine.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\event_groups.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\heap_1.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\list.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\port.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\queue.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\tasks.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\FreeRTOS821\utility\timers.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SPI\SPI.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\MinimumSerial.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SdFatUtil.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\FatFile.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\FatFileLFN.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\FatFilePrint.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\FatFileSFN.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\FatVolume.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\FmtNumber.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\StdioStream.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\fstream.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\istream.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\FatLib\ostream.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SdCard\SdSpiCard.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SdCard\SdSpiCardEX.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SdCard\SdioCardEX.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SdCard\SdioTeensy.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SpiDriver\SdSpiESP8266.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SpiDriver\SdSpiSAM3X.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SpiDriver\SdSpiSTM32F1.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\libraries\SdFat\SpiDriver\SdSpiTeensy3.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\core\wirish\start.S.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\core\wirish\start_c.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\core\wirish\syscalls.c.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\core\board.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\core\wirish\boards.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp\core\wirish\boards_setup.cpp.o" "C:\Users\michael\AppData\Local\Temp\buildd7c89daa834f4d59c2e0edd41c4c10b1.tmp/core\core.a" -Wl,--end-group
platformio is not linking many files that arduino build does
EDIT2:
Arduino is linking with this parameter
Platformio does:
-T"jtag.ld"
hmm.. is that correct ?
EDIT3:
Yes, seems that wrong linker script was the problem. I think I solved it:
I added bolded rows to arduino.py ( platformio\platforms\ststm32\builder\frameworks )
if "stm32f103r" in board.get("build.mcu", ""):
env.Replace(LDSCRIPT_PATH="bootloader.ld")
elif "stm32f103c" in board.get("build.mcu", ""):
env.Replace(LDSCRIPT_PATH="bootloader_20.ld")
elif board.get("upload.boot_version", 0) == 2:
.. and it works again
michael_l
Re: Platformio
Post by michael_l » Wed Mar 29, 2017 7:15 am
Another issue with platformio build is that it seems to create much larger flash file than Arduino IDE.
EDIT:
Added bolded rows to arduino.py and the size is approximately the same than with Arduino build.
env.Append(
CCFLAGS=[
"--param", "max-inline-insns-single=500",
"-march=armv7-m",
"-fno-exceptions",
"-fno-rtti",
"-fno-threadsafe-statics",
Re: Platformio
Post by stevestrong » Tue Apr 04, 2017 4:59 pm
Hi there,
I am currently trying to use PlatformIO for generic C8 projects, and managed to successfully build a simple blinky project.
It also uploads over DFU (manual reset):
Uploading .pioenvs\genericSTM32F103CB\firmware.bin
maple_loader v0.1
Found it!
Found Runtime: [0x1eaf:0x0003] devnum=1, cfg=0, intf=0, alt=2, name="STM32duino bootloader v1.0  Upload to Flash 0x8002000"
Setting Configuration 1...
Claiming USB DFU Interface...
Setting Alternate Setting ...
dfuIDLE, continuing
Transfer Size = 0x0400
bytes_per_hash=283
error resetting after download: usb_reset: could not reset device, win error: The system cannot find the file specified.
Done!
 [SUCCESS] Took 12.78 seconds
but...
the serial port does not appear after reset.
One of the reasons I think is that it uses the compiler "gcc version 4.8.4 20140725 (release)" instead of the 4.8.3 Q1 as standard for Arduino iDE.
Does anyone know how to configure PlatformIO to use the Arduino default compiler?
For info, here is my INI:
[env:genericSTM32F103CB]
platform = ststm32
board = genericSTM32F103CB
framework = arduino
upload_protocol = dfu
upload_port = "Maple DFU"
build_flags = -v
michael_l
Re: Platformio
Post by michael_l » Tue Apr 04, 2017 5:47 pm
stevestrong wrote:Hi there,
maple_loader v0.1
Found it!
dfuIDLE, continuing
bytes_per_hash=283
Done!
but...
platform = ststm32
framework = arduino
build_flags = -v
Please check my previous post about linker script. You may need to hack it a little. In my case platformio build put "jtag.ld" which was wrong. Because I'm using stm32duino bootloader
Re: Platformio
Post by stevestrong » Tue Apr 04, 2017 5:54 pm
@micahel_I, modifying the linker script you could set the correct compiler version?
I doubt, because it seems that PlatformIO uses for build the "toolchain-gccarmnoneeabi" folder.
michael_l
Re: Platformio
Post by michael_l » Tue Apr 04, 2017 6:03 pm
stevestrong wrote:@micahel_I, modifying the linker script you could set the correct compiler version?
Oh yes, sorry I didn't answer to your question about the compiler.
I had the same problem with platformio what you have ( no usb serial ) and fixed it with linker script. Oh and I use upload_port=serial and I have to manually reset it to get uploading started. I'll try upload_port=dfu like you.
