STM32GENERIC, my arduino implementation
michael_l
Re: STM32GENERIC, my arduino implementation
Post by michael_l » Fri May 05, 2017 7:15 pm
ChrisMicro wrote:
L476RG ah then RAM LENGTH = 128K is wrong also.
@michael
Did you try my STM32F4 Discovery examples the microphone is working a little bit ...
Nice work! I'll have to check that.
Post by Pito » Sun May 07, 2017 7:14 pm
While building for my BLUE F103ZE I get an error:
C:\Users\pito\MyCode\Sloeber\SDBench_F1\Release\arduino.ar(stm32_gpio_af.c.o): In function `AF__HAL_AFIO_REMAP_SPI3_ENABLE':
C:/Users/pito/MyCode/Arduino/hardware/Arduino_STM32SerBuff/STM32DE/system/STM32F1/stm32_chip/stm32_STM32F103ZE.h:250: undefined reference to `__HAL_AFIO_REMAP_SPI3_ENABLE'
C:\Users\pito\MyCode\Sloeber\SDBench_F1\Release\arduino.ar(stm32_gpio_af.c.o): In function `AF__HAL_AFIO_REMAP_SPI3_DISABLE':
C:/Users/pito/MyCode/Arduino/hardware/Arduino_STM32SerBuff/STM32DE/system/STM32F1/stm32_chip/stm32_STM32F103ZE.h:249: undefined reference to `__HAL_AFIO_REMAP_SPI3_DISABLE'
Enclosed the BLUE F103 ZE variant:
BLUE_F103ZE.rar
(8.19 KiB) Downloaded 10 times
UPDATE: I've added into the file \system\STM32F1\HAL_Inc\stm32f1xx_hal_gpio_ex.h, line 512:
#define AFIO_MAPR_SPI3_REMAP                 ((uint32_t)0x10000000)
such it compiles now, but I doubt it is the right way to do.. :)
Post by Pito » Sun May 07, 2017 9:30 pm
This seems does not work here with F103 core (Serial or Serial1 or SeriaUART1) on PA9, PA10 :
  while (!Serial.available()) {
UPDATE - it is because the Serial RX does not work..
UPDATE1 - Serial RX works on F407
Post by victor_pv » Mon May 08, 2017 4:04 am
Pito wrote:This seems does not work here with F103 core (Serial or Serial1 or SeriaUART1) on PA9, PA10 :
Is the core trying to use HW flow control? if it is that could conflict with the usb pins, and perhaps some function is returing with an error.
danieleff
Post by danieleff » Mon May 08, 2017 4:28 am
Hmm it does work on my maple mini.
Post by Pito » Mon May 08, 2017 6:35 am
The receive does not work here with F103ZE, I do not have MapleMini handy now, but it did not not work with MM either.
Can you confirm you can enter data into MMini via SerialUART?
danieleff
Post by danieleff » Mon May 08, 2017 6:44 am
I only tried connecting rx-tx, then SerialUART1.write(5), if (SerialUART1.available()) {if (SerialUART1.read() == 5) {...}}
By the way, transmitting works? (both are implemented with interrupt ringbuffer)
Post by Pito » Mon May 08, 2017 7:00 am
TX works as we can print the results of our experiments :)
The RX does not.. I will try with a demo..
//#define Serial SerialUART1
//#define Serial Serial1
int incomingByte = 0;   // for incoming serial data
        Serial.println("Serial Demo, enter a char:");
        if (Serial.available() > 0) {
                incomingByte = Serial.read();
                Serial.print("I received: ");
                Serial.println(incomingByte, HEX);
Nope with UART.. (BLUE F103ZE, PA9, PA10)
SerialUSB works:
I received: D
I received: A
I received: 68
I received: 6A
I received: 6B
I received: 6F
I received: 73
It works with Serial1 on libmaple F103ZE too..
danieleff
Post by danieleff » Mon May 08, 2017 5:55 pm
I think I found the fix for UART RX on F1, committed.
Post by victor_pv » Tue May 09, 2017 4:05 am
!Serial doesn't work for the USB, it's set to return always false, can we change it?
This seems ro work fine for me on F1:
SerialUSBClass::operator bool()
	// this is here to avoid spurious opening after upload
	if (millis() < 500)
		return false;
	bool result = false;
	if(hUsbDeviceFS.dev_state == USBD_STATE_CONFIGURED){
		result = true;
/* 	if (_usbLineInfo.lineState > 0)
		result = true;
	delay(10); */
	return result;
