STM32GENERIC, my arduino implementation
Re: STM32GENERIC, my arduino implementation
Post by Pito » Tue May 09, 2017 7:02 pm
danieleff wrote:I think I found the fix for UART RX on F1, committed.
ok
Post by Pito » Tue May 09, 2017 11:14 pm
While trying to print out an
uint64_t sum;
I get
error: call of overloaded 'println(uint64_t&)' is ambiguous
     Serial.println(sum);
danieleff
Post by danieleff » Wed May 10, 2017 5:31 pm
Added Mass Storage to the USB menu. I hope I did not break SerialUSB. (Both do not work at the same time).
Given I don't know what the API should be (it will probably be something like `setupMassStorate(...)` that the user has to implement), here is testing code for unformatted ramdisk, tested only on black 407ve:
#include "msc/usbd_msc.h"
const uint8_t MSC_Inquirydata[] = {
  /* LUN 0 */
  0x00,
  0x80,
  0x02,
  0x02,
  (STANDARD_INQUIRY_DATA_LEN - 5),
  0x00,
  0x00,
  0x00,
  'S', 'T', 'M', ' ', ' ', ' ', ' ', ' ', /* Manufacturer : 8 bytes */
  'P', 'r', 'o', 'd', 'u', 'c', 't', ' ', /* Product      : 16 Bytes */
  '0', '.', '0' ,'1',                     /* Version      : 4 Bytes */
const uint16_t blockSize = 512;
const uint32_t blockCount = 100;
uint8_t ramdisk[blockSize * blockCount] = {0};
namespace Testing {
// See UM1734, 6.2.4
// See usbd_msc.h
USBD_StorageTypeDef USBD_DISK_fops = {
    //Init
    [](uint8_t lun) -> int8_t {
        return USBD_OK;
    //GetCapacity
    [](uint8_t lun, uint32_t *block_num, uint16_t *block_size) -> int8_t {
        *block_num  = blockCount;
        *block_size = blockSize;
        return USBD_OK;
    //IsReady
        return USBD_OK;
    //IsWriteProtected
        return USBD_OK;
    //Read
    [](uint8_t lun, uint8_t *buf, uint32_t blk_addr, uint16_t blk_len) -> int8_t {
        memcpy(buf, ramdisk + blk_addr * blockSize, blk_len * blockSize);
        return USBD_OK;
    //Write
        digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
        memcpy(ramdisk + blk_addr * blockSize, buf, blk_len * blockSize);
        return USBD_OK;
    //GetMaxLun
    []() -> int8_t {return 0;},
    (int8_t *)MSC_Inquirydata
    pinMode(LED_BUILTIN, OUTPUT);
If you have problems, try to debug, it is unbelivalby hard to debug USB even on own computer.
Pito: There is no print(uint64_t) (yet) which is why it is giving error.
Post by RogerClark » Thu May 11, 2017 2:12 am
stevestrong wrote:I think we desperately need a separate "STM32generic" entry under "Bootloaders and cores",
so that each issue can be discussed in separate thread.
Belated.. I've now done this.
FYI.
I someone PM'ed me, I would have done this before.
I had to unexpected be away from home (overseas) since the end of March, and I've only been back at home for a short while, so I'm now trying to read several long threads, including this one ;-)
Edit.
Daniel has asked me to move all the threads to the new section, so I've done that, apart from this thread (and I may move it if Daniel wants me to)
michael_l
Post by michael_l » Thu May 11, 2017 4:58 am
michael_l wrote:
ChrisMicro wrote:
L476RG ah then RAM LENGTH = 128K is wrong also.
@michael
Did you try my STM32F4 Discovery examples the microphone is working a little bit ...
Nice work! I'll have to check that.
Just tried this and I can confirm it works. It's fun ! I have to educate myself a bit more about I2S and PDM. Looks like PDM processing is more complicated than I thought originally.
ChrisMicro
Post by ChrisMicro » Thu May 11, 2017 6:50 am
Thanks for trying :D
The problem with the PDM-microphone is that I had to clock it by "bit banging" ~2.3Mhz and my somehow poor filter implementation.
I think, it could be improved ...
STM has a closed source library, but I don't want to use closed source libraries.
Post by Pito » Thu May 11, 2017 4:54 pm
danieleff wrote:Pito: There is no print(uint64_t) (yet) which is why it is giving error.
There is, but we have got problems with long vs long long vs int32_t vs int64_t types in print/println definitions, it seems..
Print.h
The maple does it (and it works):
size_t Print::printNumber(unsigned long long n, uint8 base)
    size_t print(long long, int=DEC);
    size_t print(unsigned long long, int=DEC);
here:
    size_t print(long, int = DEC);
    size_t print(unsigned long, int = DEC);
size_t Print::printNumber(unsigned long n, uint8 base)
Here the long int is 32bit, sure..
I added the long long defs but getting an error
"C:\Users\pito\MyCode\Arduino\hardware\Arduino_STM32SerBuff\STM32DE\cores\arduino\Print.cpp"  -o  "core\Print.cpp.o"
C:\Users\pito\MyCode\Arduino\hardware\Arduino_STM32SerBuff\STM32DE\cores\arduino\Print.cpp:239:8: error: prototype for 'size_t Print::printNumber(long long unsigned int, uint8_t)' does not match any in class 'Print'
 size_t Print::printNumber(unsigned long long n, uint8_t base)
I do not know where
comes from..
Edit: libmaple_types are used in maple, we do not use it Here..
I've added
typedef unsigned long long uint64_t;
typedef long long int64_t;
in the Print.h but still above error.[/s]
OK FIXED..
Here are the two files Print.h and Print.cpp - with added signed/unsigned print/println of 64bitters:
Print.zip
(3.05 KiB) Downloaded 12 times
ChrisMicro
Post by ChrisMicro » Fri May 12, 2017 2:13 pm
@Daniel
I just tried to compile the both examples in the Black407VE folder. But it didn't work: the include files are missing :!:
danieleff
Post by danieleff » Sat May 13, 2017 4:46 am
ChrisMicro wrote:@Daniel
You need to install the libraries that are in the first line in the .ino in comments. (SPIFlash from library manager and SdFat-beta from github)
ChrisMicro
Post by ChrisMicro » Sat May 13, 2017 5:22 am
The problem is: where to find? Can you provide the links?
The best thing for examples would be if they simply compile and run. Would it make sense to include the libraries in the repository?
If not, it would be very helpful to have a link in the description header of the example.
BTW.: I have added new basic examples for the BLACK407VE
I also tried the analogReadSerial-example from the main Arduino examples. I had to replace A0 by e.g. PA0.
The USB-serial worked fine with 115200 baud but hung with 9600baud.
The Ram-Free Examples shows only 124KB RAM instead of 196KB RAM.
