STM32GENERIC, my arduino implementation
acronis
Re: STM32GENERIC, my arduino implementation
Post by acronis » Wed Jun 14, 2017 1:32 am
Hello.
I tried this example.
He poured without errors but the screen is blank .
What could be the problem ?
danieleff
Post by danieleff » Wed Jun 14, 2017 4:06 am
acronis wrote:3.2 inch TFT LCD screen with resistive touch screens ILI9341 display module
especially for black Board STM32F407VET6
https://ru.aliexpress.com/item/3-2-inch ... Title=true
This is the first time I actually see a display with the matching connector to the board.
stevestrong has library for 16 bit parallel display https://github.com/stevstrong/Adafruit_ ... 6bit_STM32
I think you will need his version of the libmaple core: https://github.com/stevstrong/Arduino_S ... F4_variant
acronis
Post by acronis » Wed Jun 14, 2017 4:30 am
Well. Thank you. I will try.
ChrisMicro
Post by ChrisMicro » Wed Jun 14, 2017 7:02 am
Sorry, arconis, I didn't see that the display has a parallel interface.
I'm very curious if it is working and if so, it would be very useful to add the working solution to the examples folder.
Post by zmemw16 » Thu Jun 15, 2017 5:40 pm
two^H^H^H^H5 questions
@acronis
did you get it working ?
could you share the TFTLCD h file?
steve
when you say generic f407v, which board are you thinking of ? Black F407VE schematic? it matches
i've got my Black F407VE with compatible display inserted, the led is going nicely clappers :) , display is blank :(
any suggestions ?
edit answered 2q's
Post by Pito » Thu Jun 15, 2017 5:55 pm
I got a similar display but with 40pins :(
I doubt it fits.. :P
@stephen - is your display the one from acronis link?
Post by stevestrong » Thu Jun 15, 2017 7:16 pm
I am talking about the black f4vet6 board.
I also own a mini f4vet6 board, but did not test it yet.
I have transformed the ili9486 SPI diplay for 16 bit parallel access and used it with FSMC., see benchmark here:
http://www.stm32duino.com/viewtopic.php ... 150#p28314
Post by zmemw16 » Thu Jun 15, 2017 8:11 pm
they're 32 way, the display for the black f407 ve and ze boards is socketed, the zgt is a 34 way pin header
there's another difference in the pin outs,ve&ze vers zg boards, not quite sure how i missed that.
i was checking the f407ve schematic against the tftlcd_16bit library files as it was described as a generic f407, header file matches the black f407ve circuit.
curiously there are a couple pins that have an adjacent 'zet' annotation.
this setup requires stevstrong black_f4_variant repo installed
i've tried the graphic test, compiles and it has a flashing led, enable the actual graphics bits and the compile/link messages window turns really orange.
doesn't see the header files listed in pin_map.c
the ide also doesn't want to change the port, only one is /dev/ttyACM3, insists on reporting /dev/ttyACM0 is not there. even though i restarted it with an edited preferences.txt setting it.
headers / socket attached, this is graphic.xcf, compressed with gzip, split into 3 parts and renamed to .txt
i noted keypunch 's comment about 3 files max :D
re-assembly is left to the student :D
hdr-sktac.txt
(68.36 KiB) Downloaded 12 times
hdr-sktab.txt
(78 KiB) Downloaded 6 times
hdr-sktaa.txt
(78 KiB) Downloaded 8 times
acronis
Post by acronis » Fri Jun 16, 2017 11:47 am
Hello. IDE 1.8.2 , you have the library installed stevestrong has the libraries for 16 bit parallel display and https://github.com/stevstrong/Adafruit_ ... 6bit_STM32 https://github.com/stevstrong/Arduino_S ... F4_variant . example Graphisctest. error
In file included from C:\Users\VIC\ Documents\Arduino\\libraries Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino:7:0:
C:\Users\VIC\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h in the void writeCommand function '(uint16_t)':
C:\Users\VIC\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:64:22: error: 'fsmcCommand' was not declared in this area
#define lcdCommand (*fsmcCommand)
C:\Users\Виктор\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:68:27 note: in expansion of macro 'lcdCommand'
#define writeCmd(d) { lcdCommand = d; } //(l&0x00FF); }
C:\Users\VIC\Documents\Arduino\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:200:2 note: in expansion of macro writeCmd"
writeCmd ();
Post by stevestrong » Fri Jun 16, 2017 12:49 pm
As this thread is dedicated for STM32GENRIC developed by Daniel, and my generic_f4 branch is based on libmaple core and not based on this, I would suggest to not put here issues related to my lib.
So please post issues related to 16 parallel display either here or make a new thread: viewforum.php?f=39.
Issues related in general to my branch, please post here: http://www.stm32duino.com/viewtopic.php?f=39&t=1976
