peripherals in cores
turboscrew
Post by turboscrew » Sun Dec 24, 2017 8:54 am
Where can I find out the devices and GPIO-pins used by the cores?
I'm using blue pill, and I'd like to know what resources does Serial.Println() use. Does it use DMA as FIFO?
Also on my blue pill SPI1 NSS doesn't work - it doesn't go high when the SPI is disabled - well, it does, but a lot later, so the default NSS-pin can't be used at all. (Haven't tried the other SPIs.)
Re: peripherals in cores
Post by stevestrong » Sun Dec 24, 2017 10:17 am
Arduino_STM32 core
Serial is mapped to USB serial interface, if you have enabled -DSERIAL_USB in the boards.txt.
Otherwise serial is mapped to USART 1 interface, which uses PA9/10.
None of the serial interfaces uses DMA.
The NSS pin has to be controlled by the user:
#define NSS_PIN PA4 // you can use any other available pin
pinMode(NSS_PIN, OUTPUT);
digitalWrite(NSS_PIN, HIGH); // deactivate slave select
If none of these information helped, do you have a simple sketch which can reproduce your problem?
turboscrew
Post by turboscrew » Sun Dec 24, 2017 10:49 am
My "problem" is more like trying to get RFM69 library to work, and that includes having the right wires to right pins.
There are also serial prints, that I'd wish to get to my development computer terminal.
I'd also just like to know where to find the definitions, if I use some other libraries in the future, so my question is kind of generic.
Also, if there is:
genericSTM32F103C.menu.upload_method.STLinkMethod.build.upload_flags=-DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER
Does it mean that only USB-serial is used, or can I upload with ST-LINK-V2 and use USB-serial cable between my computer and the board?
turboscrew
Post by turboscrew » Sun Dec 24, 2017 11:20 am
Thanks! That helps.
Post by stevestrong » Sun Dec 24, 2017 11:30 am
Yes, USB serial is enabled, so you can output data to PC over USB cable.
And yes, you can upload with STLink (although pressing the reset button may be necessary).
turboscrew
Post by turboscrew » Sun Dec 24, 2017 11:34 am
Went a bit further and found this: https://github.com/rogerclarkmelbourne/ ... rd/board.h
This seems to go a long way. It also suggests, that SysTick is used as a "main clock".
turboscrew
Post by turboscrew » Sun Dec 24, 2017 11:36 am
I wonder if you can have serial output while debugging via ST-LINK...?
Post by stevestrong » Sun Dec 24, 2017 11:40 am
No, see here: viewtopic.php?f=35&t=3018
turboscrew
Post by turboscrew » Sun Dec 24, 2017 11:54 am
I was wondering if ST-LINK was kept as a debug interface and USART1 could easily been configured as 'Serial'...
Uh, I guess I just need to remove the "USB_SERIAL" and use, say, Eclipse/OpenOCD for uploading and debugging via ST-LINK?
