No fix on u-blox neo 6m
External hardware connected to the STM32 board
Re: No fix on u-blox neo 6m
Post by RogerClark » Wed Jun 14, 2017 10:20 pm
Thanks for letting us know the outcome.
Can you change the thread title, to indicate you now have a fix.
ilf
Post by ilf » Wed Jun 21, 2017 5:27 pm
Hi Roger, sorry for not getting back earlier, got a bit of a flu or something. This actually is not my thread, I shamelessly hijacked it, because it was exactly the same situation I was facing. Sidenote, with a bit of help from Tomtor LoRaWAN is working flawlessly with Arduino-LMIC lib. I don't know what is the proper way of reporting working libs, but if someone does a search - LMIC works, you just need tomtor's LMIC github repo. :D
Post by RogerClark » Wed Jun 21, 2017 10:36 pm
People sometimes post to the libraries section if they have ported a library, or if they find a particular library works with no changes.
I should probably formalise this.
I should probably do something similar for hardware, e.g. I tried one of those H Bridge motor controllers the other day, and it seemed to work fine wirh 3.3v PWM
Post by ahull » Thu Jun 22, 2017 8:54 am
Sounds like a good thing to put in the Wiki, perhaps a section for working hardware and a section for working libraries.
jucordero
Post by jucordero » Fri Jul 14, 2017 12:40 pm
Ilf, thank you for reviving this post. I actually could not resolve the issue. Even changed the LDO for two maple mini clones with no results, but never tried removing the breadboard from the equation. I'll give it a try today so we can have a larger sample of results.
Post by mrburnette » Sat Jul 15, 2017 3:42 pm
... There is not an issue with Neo 6 and the Maple Mini clone - I have used both many times with Adafruit's GPS library and even my own non-library parsing function. I do however use the 9600 BAUD default serial speed of the ublox.
Example project
When the Neo6's arrive from China, they will take a very long time to get the first fix; My worst case was over 10 hours.
Post by RogerClark » Sat Jul 15, 2017 9:09 pm
Ray,
Can you an approximate location to the GPS to help it with its initial fix?
I think some GPS units support this.
Also puttin the unit outside so it gets a clear view of as many satellites as possible normally speeds up acquisition time.
