Touchscreen_stm with STM32F103
External hardware connected to the STM32 board
Jabir
Post by Jabir » Wed Sep 13, 2017 10:38 am
Hello,
I want to connect "3.2inch Plug-and-play LCD for Raspberry"
LCD Pin.png (19.96 KiB) Viewed 249 times
For that I use this program:
https://github.com/rogerclarkmelbourne/ ... hpaint.ino
The question is: where to connect =====> On the LCD
#define YP PB0 // must be an analog pin
#define XM PA3 // must be an analog pin
#define YM PB7 // can be a digital pin
#define XP PC13 // can be a digital pin
Re: Touchscreen_stm with STM32F103
Post by victor_pv » Wed Sep 13, 2017 1:26 pm
That LCD has a digital touch screen controller that uses SPI, as you can see a CS for touch, and a CS for LCD.
The sketch you are referencing is for a different use, reading the touch screen with analog signals.
Jabir
Post by Jabir » Wed Sep 13, 2017 2:43 pm
Thank you very much :D
can you advise me another library that uses both SPI
Post by victor_pv » Wed Sep 13, 2017 6:43 pm
I believe there is one called utouch that has been used with our cores before. Search in the forum for some references.
