I2C SDA2 and SCL2 no success
External hardware connected to the STM32 board
Leplouc
Post by Leplouc » Sun Nov 12, 2017 9:29 am
My I2C(1) (PB6 and PB7) are used for my 8 bit TFT so I cant used them.
I tried in vain to use SDA2 and SCL2 (PB10/11) using HWire or SWire library.
A couple of topics talk about this point but nothing found..
Pse help.
Re: I2C SDA2 and SCL2 no success
Post by Pito » Sun Nov 12, 2017 9:42 am
Do write a small short sketch showing the issue and post it here such people may see it and help.
Leplouc
Post by Leplouc » Sun Nov 12, 2017 10:16 am
That's the sketch :
//       Copyright©2016.JA2GQP.All rights reserved.
//            si5351a PLL test
//                                                    2017/5/20
//                                                    JA2GQP
//       stm32f103               si5351a             Arduino nano(UNO)
//         PB6(SCL1)    ------     SCL     ------          A5
//         PB7(SDA1)    ------     SDA     ------          A4
//         3V3(3.3V)    ------     VIN     ------          5V
//         GND          ------     GND     ------          GND
//---------- include Files ---------------
#include "si5351a2.h"
HardWire HWire(1, I2C_FAST_MODE); // I2c1
//Using (1, I2C_FAST_MODE); PB6/SCL1 and PB7/SDA1 are working
//Using (2, I2C_FAST_MODE;  PB10/SCL2 and PB11/SDA2 are not working
//----------  Initialization  Program  ----------------------
  HWire.begin(2);
  Si5351_write(XTAL_LOAD_C,0x80);       //Crystal Load Capasitance=8pF
  si5351aSetFrequency(100000L);        //CLK0
  si5351aSetFrequency2(8000L);       //CLK2
//----------  Main program  ---------------------------------
Leplouc
Post by Leplouc » Sun Nov 12, 2017 10:18 am
Pse read HWire.begin() instead of HWire.begin(2)
Post by Pito » Sun Nov 12, 2017 12:33 pm
FYI: You may edit your posts anytime and freely after the posting by clicking on the "pencil" icon. Also you may delete it with the cross icon (for some time from posting).
Also paste your source code such you click on </> icon while in editor and paste the source inside..
source code.JPG (9.76 KiB) Viewed 238 times
my code here
Leplouc
Post by Leplouc » Sun Nov 12, 2017 12:41 pm
Tks Pito,
I'm quite new on the forum...
Post by RogerClark » Sun Nov 12, 2017 7:06 pm
Post a link to the library.
BTW.debugging issues like this normally need a logic analyser, luckily you can get a usb based 8 channel 24mhz logic analyser for around $10
Leplouc
Post by Leplouc » Mon Nov 13, 2017 5:17 am
I guess Hardwire is included in the Wire lib.
If I remove the TFT, my I2C board (Si5351) works perfectly with SDA1/SCL1 but no com with SDA2/SCL2.
