Good day
How do I use this bootloader with PlatformIO?
It works perfectly under Arduino without fail, so thank you so much for your hard work on this. Under macOS, I have found that only Serial upload worked perfectly each time. Now I can add the STM32 HID bootloader to this list
TIA
How to use with PlatformIO?
Thank you for your reply. I started working on a custom uploader, which was able to find the PB and started uploading, but the blink program never executed and the serial port was missing after the upload. I knew it had to do with some build flags, but I had no idea which ones, so I put it on ice.
By chance, I read this post stm32 shows up on dmesg but not in arduino ide #34 which lead me to Notes on using STM32F103C8T6 Blue Pill. I watched the video How to Install the STM32 USB Bootloader - Tutorial Video. Towards the end was info on how to get the HID bootloader working in PlatformIO. I modified my platformio.ini file accordingly, but the upload failed with sh: hid-flash: command not found
A quick Google led me to [sh: hid-flash: command not found] Error when using hid upload protocol with stm32 bluepill. The fix is to copy the appropriate hid-flash program to the appropriate folder. I do not have framework-arduinoststm32-maple so I downloaded and copied hid-flash from STM32_HID_Bootloader
Now, everything works fine
Go to full postBy chance, I read this post stm32 shows up on dmesg but not in arduino ide #34 which lead me to Notes on using STM32F103C8T6 Blue Pill. I watched the video How to Install the STM32 USB Bootloader - Tutorial Video. Towards the end was info on how to get the HID bootloader working in PlatformIO. I modified my platformio.ini file accordingly, but the upload failed with sh: hid-flash: command not found
Pieter
macOS: 14.5 M1
Arduino: 1.8.19
Arduino IDE: 2.3.2
STM32 Core: 2.7.1
macOS: 14.5 M1
Arduino: 1.8.19
Arduino IDE: 2.3.2
STM32 Core: 2.7.1
Re: How to use with PlatformIO?
With platformio you can define your own custom uploader
https://docs.platformio.org/en/latest/p ... pload-tool
Pieter
macOS: 14.5 M1
Arduino: 1.8.19
Arduino IDE: 2.3.2
STM32 Core: 2.7.1
macOS: 14.5 M1
Arduino: 1.8.19
Arduino IDE: 2.3.2
STM32 Core: 2.7.1
Thanks for your valuable input. I experienced the same: the hid-flash tool of PlatformIO is outdated and can not cope with the 2.2.1 bootloader.
After copying the executable into the platform-IO tools directory, the upload works.
But I had to use a slightly changed environment I want to share:
Please be aware of "USB_VID"! That key was more or less a good guess after looking into the log files.
The upload_port depended on the port Windows (in my case) set up the device as 'STM Device'.
[env:bluepill_f103c8_128k]
platform = ststm32
board = bluepill_f103c8_128k
framework = arduino
upload_protocol = hid
upload_port = COM8
build_flags =
-D PIO_FRAMEWORK_ARDUINO_ENABLE_CDC
-D USBCON
-D USB_VID=0x0483
-D USB_MANUFACTURER="Unknown"
-D USB_PRODUCT="\"BLUEPILL_F103C8\""
-D HAL_PCD_MODULE_ENABLED
lib_extra_dirs = ~/Documents/Arduino/libraries
Just incase anyone finds this and is still struggling...
I'm using a Mac, and moving from the Arduino IDE, and I already had this Bootloader working for the Bluepill under the Arduino IDE...
/Users/**yourusername**/Library/Arduino15/packages/STM32/tools/STM32tools/**versionnumber**/macosx/hid-flash
Straight into:
/Users/** yourusername**/.platformio/packages/tool-stm32duino
This made the HID-flash available in PlatformIO, but still failed to upload, and spat out this in the terminal:
So I then copied the address from an Arduino IDE Upload (cu.usbmodem024EB5C953471) to the platform.ini file:
I'm pretty sure I'd have to change this if I changed USB port or the Board, but you could always figure it from the Arduino IDE on your machine.
For clarification, as I also didn't have a framework-arduinoststm32-maple folder, I ended up copying HID-Flash from my Arduino packages folder:Kenjutsu wrote: ↑Mon May 25, 2020 8:35 am By chance, I read this post stm32 shows up on dmesg but not in arduino ide #34 which lead me to Notes on using STM32F103C8T6 Blue Pill. I watched the video How to Install the STM32 USB Bootloader - Tutorial Video. Towards the end was info on how to get the HID bootloader working in PlatformIO. I modified my platformio.ini file accordingly, but the upload failed with sh: hid-flash: command not found
Straight into:
Error - [1209:BEBA] device is not found :(> Searching for [COM17] ...
error, counldn't open [/dev/COM17]
upload_port = cu.usbmodem024EB5C953471
