8-bit|16-bit parallell ILI9341
External hardware connected to the STM32 board
Re: 8-bit|16-bit parallell ILI9341
Post by stevestrong » Wed Aug 30, 2017 6:26 pm
I think your problem is the RST pin.
It may not be defined to PA0, because this translates to value 0:
https://github.com/rogerclarkmelbourne/ ... oard.h#L80
and then the RST pin will not be toggled:
https://github.com/stevstrong/Arduino_S ... TM.cpp#L78
I think I should correct the software to test for ">=0".
Till then try to use any other pin for RST.
And, as I told, PA4 should work as CS. To check that, write a simple test program to toggle it.
aster
Post by aster » Thu Aug 31, 2017 4:37 pm
wow, with more than 30 pins i choose the only one which wouldn't work :lol:
i am happy my bad luck helped you spotted a small error in the library
by the way the problem with PA4 i was referring was this: viewtopic.php?f=44&p=33802#p33802 but looks like it was solved time ago
Now i thinks it is better to stop spamming this thread and maybe an admin could move these last post in the correct one
MakcYan
Re: В 8-бит|16-бит параллельно ILI9341
Post by MakcYan » Thu Oct 26, 2017 5:36 am
Hello.
I can not initialize the display ili9431 16-bit. Only the white screen appears.
Tell me please what I'm doing wrong?
Use the stm32f103c8t6 blue board + Arduino IDE 1.8.4 + Arduino_STM32 + library Adafruit_TFTLCD_16bit_STM32 (//#define USE_FSMC 1 in Adafruit_TFTLCD_16bit_STM32.h) + the sketch
Connection:
D0...D15 - PB0...15 (PB2 - removed the jumper and connected to pin)
WR, RS, CS - PA1,PA2,PA3
RST - PC15
RD - connected to 3.3v and GND
If I use the library Adafruit_ILI9341_8bit_STM (iwalpola) with recommended connection pins, the image appears, but only used the blue color and its shades.
P.S.
Wrote the text using google translate from Russian language
Post by stevestrong » Thu Oct 26, 2017 8:38 am
Can you please give a try and change
1. the line https://github.com/stevstrong/Adafruit_ ... M32.h#L103
to
#if 1
So basically activate the standard bit toggling using digitalWrite().
2. In line https://github.com/stevstrong/Adafruit_ ... M32.h#L149
replace Adafruit_GFX by "Adafruit_GFX_AS"
Do you get any warnings during build?
MakcYan
Post by MakcYan » Thu Oct 26, 2017 2:40 pm
In file included from C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino:7:0:
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\src/Adafruit_TFTLCD_16bit_STM32.h:149:60: error: expected class-name before '{' token
 class Adafruit_TFTLCD_16bit_STM32 : public Adafruit_GFX_AS {
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'void setup()':
graphicstest:20: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   Serial.print("TFT size is "); Serial.print((uint16_t)tft.width()); Serial.print("x"); Serial.println((uint16_t)tft.height());
graphicstest:20: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'height'
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testText()':
graphicstest:179: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setCursor'
   tft.setCursor(0, 0);
graphicstest:180: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextColor'
   tft.setTextColor(WHITE);  tft.setTextSize(1);
graphicstest:180: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextSize'
graphicstest:181: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("Hello World!");
graphicstest:182: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextColor'
   tft.setTextColor(YELLOW); tft.setTextSize(2);
graphicstest:182: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextSize'
graphicstest:183: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println(1234.56);
graphicstest:184: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextColor'
   tft.setTextColor(RED);    tft.setTextSize(3);
graphicstest:184: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextSize'
graphicstest:185: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println(0xDEADBEEF, HEX);
graphicstest:186: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println();
graphicstest:187: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextColor'
   tft.setTextColor(GREEN);
graphicstest:188: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextSize'
   tft.setTextSize(5);
graphicstest:189: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("Groop");
graphicstest:190: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextSize'
   tft.setTextSize(2);
graphicstest:191: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("I implore thee,");
graphicstest:192: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'setTextSize'
   tft.setTextSize(1);
graphicstest:193: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("my foonting turlingdromes.");
graphicstest:194: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("And hooptiously drangle me");
graphicstest:195: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("with crinkly bindlewurdles,");
graphicstest:196: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("Or I will rend thee");
graphicstest:197: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("in the gobberwarts");
graphicstest:198: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("with my blurglecruncheon,");
graphicstest:199: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'println'
   tft.println("see if I don't!");
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testLines(uint16_t)':
graphicstest:206: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
                 w = tft.width(),
graphicstest:212: error: 'h' was not declared in this scope
   y2    = h - 1;
graphicstest:214: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
   for(x2=0; x2<w; x2+=6) tft.drawLine(x1, y1, x2, y2, color);
graphicstest:216: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
   for(y2=0; y2<h; y2+=6) tft.drawLine(x1, y1, x2, y2, color);
graphicstest:225: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
graphicstest:227: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
graphicstest:236: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
graphicstest:238: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
graphicstest:247: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
graphicstest:249: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawLine'
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testFastLines(uint16_t, uint16_t)':
graphicstest:256: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   int           x, y, w = tft.width(), h = tft.height();
graphicstest:260: error: 'h' was not declared in this scope
   for(y=0; y<h; y+=5) tft.drawFastHLine(0, y, w, color1);
graphicstest:261: error: 'h' was not declared in this scope
   for(x=0; x<w; x+=5) tft.drawFastVLine(x, 0, h, color2);
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testRects(uint16_t)':
graphicstest:269: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
                 cx = tft.width()  / 2,
In file included from C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish.h:60:0,
                 from C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\cores\maple/Arduino.h:30,
                 from C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino:1:
graphicstest:273: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   n     = min(tft.width(), tft.height());
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish_math.h:108:35: note: in definition of macro 'min'
 #define min(a,b)                ((a)<(b)?(a):(b))
graphicstest:273: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'height'
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish_math.h:108:39: note: in definition of macro 'min'
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish_math.h:108:43: note: in definition of macro 'min'
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\cores\maple/wirish_math.h:108:47: note: in definition of macro 'min'
graphicstest:277: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawRect'
     tft.drawRect(cx-i2, cy-i2, i, i, color);
graphicstest:277: error: 'cy' was not declared in this scope
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testFilledRects(uint16_t, uint16_t)':
graphicstest:286: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
                 cx = tft.width()  / 2 - 1,
graphicstest:290: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
graphicstest:290: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'height'
graphicstest:294: error: 'cy' was not declared in this scope
     tft.fillRect(cx-i2, cy-i2, i, i, color1);
graphicstest:297: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawRect'
     tft.drawRect(cx-i2, cy-i2, i, i, color2);
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testFilledCircles(uint8_t, uint16_t)':
graphicstest:305: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   int x, y, w = tft.width(), h = tft.height(), r2 = radius * 2;
graphicstest:309: error: 'r2' was not declared in this scope
   for(x=radius; x<w; x+=r2) {
graphicstest:310: error: 'h' was not declared in this scope
     for(y=radius; y<h; y+=r2) {
graphicstest:311: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'fillCircle'
       tft.fillCircle(x, y, radius, color);
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testCircles(uint8_t, uint16_t)':
graphicstest:321: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
                 w = tft.width()  + radius,
graphicstest:328: error: 'h' was not declared in this scope
     for(y=0; y<h; y+=r2) {
graphicstest:329: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawCircle'
       tft.drawCircle(x, y, radius, color);
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testTriangles()':
graphicstest:338: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   int           n, i, cx = tft.width()  / 2 - 1,
graphicstest:342: error: 'cy' was not declared in this scope
   n     = min(cx, cy);
graphicstest:345: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawTriangle'
     tft.drawTriangle(
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testFilledTriangles()':
graphicstest:357: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   int           i, cx = tft.width()  / 2 - 1,
graphicstest:362: error: 'cy' was not declared in this scope
   for(i=min(cx,cy); i>10; i-=5) {
graphicstest:364: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'fillTriangle'
     tft.fillTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
graphicstest:367: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawTriangle'
     tft.drawTriangle(cx, cy - i, cx - i, cy + i, cx + i, cy + i,
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testRoundRects()':
graphicstest:377: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
graphicstest:381: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   w     = min(tft.width(), tft.height());
graphicstest:381: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'height'
graphicstest:385: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'drawRoundRect'
     tft.drawRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(i, 0, 0));
graphicstest:385: error: 'cy' was not declared in this scope
C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master\examples\graphicstest\graphicstest.ino: In function 'long unsigned int testFilledRoundRects()':
graphicstest:394: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
graphicstest:399: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'width'
   for(i=min(tft.width(), tft.height()); i>20; i-=6) {
graphicstest:399: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'height'
graphicstest:401: error: 'class Adafruit_TFTLCD_16bit_STM32' has no member named 'fillRoundRect'
     tft.fillRoundRect(cx-i2, cy-i2, i, i, i/8, tft.color565(0, i, 0));
graphicstest:401: error: 'cy' was not declared in this scope
Используем библиотеку Adafruit_TFTLCD_16bit_STM32-master версии 1.0.0 из папки: C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_TFTLCD_16bit_STM32-master
Используем библиотеку Adafruit_GFX_AS в папке: C:\Users\MAKC-admin\Desktop\arduino-1.8.4\hardware\Arduino_STM32-master\STM32F1\libraries\Adafruit_GFX_AS (legacy)
exit status 1
Post by stevestrong » Thu Oct 26, 2017 5:33 pm
OK, so 2. that was a bad idea.
Change it back, please.
Have you tried 1.?
MakcYan
Post by MakcYan » Thu Oct 26, 2017 5:59 pm
point 1 I tried, then I 2 a point used.
After a point 1 on a display nothing appeared(
vegfokic
Post by vegfokic » Thu Oct 26, 2017 6:58 pm
Hello MakcYan
I also have white screen with 16 bit library from Steve.
Did you checked the serial monitor?
My serial monitor prints out the test result just the lcd white.
Post by stevestrong » Thu Oct 26, 2017 7:26 pm
I think there is a simple reason why it is not working: there is bug here: https://github.com/stevstrong/Adafruit_ ... M32.h#L138 :mrgreen:
Please replace 0x44444444 by 0x33333333, in both places.
Mode value 4 means input floating, value 3 means output 50MHz.
So the line should look like:
 #define setWriteDir() { TFT_DATA_PORT->regs->CRL = 0x33333333; TFT_DATA_PORT->regs->CRH = 0x33333333; } // set the bits as output
MakcYan
Post by MakcYan » Fri Oct 27, 2017 2:32 pm
After changing 0x44444444 - 0x33333333 on the image on the screen has not changed - white screen.
I have my doubts about the pin PB2, resistor 100K Ohm can affect the work?
I'll try to switch the configuration pins of the controller to work with 8 bits.
