How do I create a definition for a Board (BTT EBB42)
Posted: Sat Aug 06, 2022 12:03 pm
Hi everyone
I'm wondering if anyone can advise how I need to go about creating a definition for a board that uses a 8Hz external clock, as that information looks to be currently missing from the Wiki.
The board in question is a Big Tree Tech 3D printer (sub) control board, called "EBB42 v1.1" and utilises the STM32G0B1CBT6 MCU
https://github.com/bigtreetech/EBB/tree ... CAN%20V1.1
I have added the board definition, created the files in the variant folder inline with other boards as an example.
It doesn't show up in Arduino 1.8.19 menu, I'm not sure what I'm missing, please advise.
boards.txt
variant_EBB42_V1_1.cpp
variant_EBB42_V1_1.h
boards.txt
# 3D printer boards
# BTT_EBB42_V1.1 board
3dprinter.menu.pnum.EBB42_V1_1=BTT EBB42 v1.1
3dprinter.menu.pnum.EBB42_V1_1.upload.maximum_size=131072
3dprinter.menu.pnum.EBB42_V1_1.upload.maximum_data_size=147456
3dprinter.menu.pnum.EBB42_V1_1.build.mcu=cortex-m0plus
3dprinter.menu.pnum.EBB42_V1_1.build.board=EBB42_V1_1
3dprinter.menu.pnum.EBB42_V1_1.build.series=STM32G0xx
3dprinter.menu.pnum.EBB42_V1_1.build.product_line=STM32G0B1xx
3dprinter.menu.pnum.EBB42_V1_1.build.variant=STM32G0xx/G0B1C(B-C-E)(T-U)_G0C1C(C-E)(T-U)
3dprinter.menu.pnum.EBB42_V1_1.build.peripheral_pins=-DCUSTOM_PERIPHERAL_PINS
3dprinter.menu.pnum.EBB42_V1_1.build.cmsis_lib_gcc=arm_cortexM0l_math
* Copyright (c) 2021, STMicroelectronics
* All rights reserved.
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
#if defined(ARDUINO_EBB42_V1_1)
#include "pins_arduino.h"
// Pin number
const PinName digitalPin[] = {
PA_0, // D0/A0
PA_1, // D1/A1
PA_2, // D2/A2
PA_3, // D3/A3
PA_4, // D4/A4
PA_5, // D5/A5
PA_6, // D6/A6
PA_7, // D7/A7
PA_8, // D8
PA_9, // D9
PA_10, // D10
PA_11, // D11
PA_12, // D12
PA_13, // D13
PA_14, // D14
PA_15, // D15
PB_0, // D16/A8
PB_1, // D17/A9
PB_2, // D18/A10
PB_3, // D19
PB_4, // D20
PB_5, // D21
PB_6, // D22
PB_7, // D23
PB_8, // D24
PB_9, // D25
PB_10, // D26/A11
PB_11, // D27/A12
PB_12, // D28/A13
PB_13, // D29
PB_14, // D30
PB_15, // D31
PC_6, // D32
PC_7, // D33
PC_13, // D34
PC_14, // D35
PC_15, // D36
PD_0, // D37
PD_1, // D38
PD_2, // D39
PD_3, // D40
PF_0, // D41
PF_1, // D42
PF_2, // D43
PA_9_R, // D44
PA_10_R // D45
// Analog (Ax) pin number array
const uint32_t analogInputPin[] = {
0, // A0, PA0
1, // A1, PA1
2, // A2, PA2
3, // A3, PA3
4, // A4, PA4
5, // A5, PA5
6, // A6, PA6
7, // A7, PA7
16, // A8, PB0
17, // A9, PB1
18, // A10, PB2
26, // A11, PB10
27, // A12, PB11
28 // A13, PB12
#ifdef __cplusplus
extern "C" {
* @brief System Clock Configuration
* @param None
* @retval None
HAL_PWREx_ControlVoltageScaling(PWR_REGULATOR_VOLTAGE_SCALE1);
RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE|RCC_OSCILLATORTYPE_HSI48;
RCC_OscInitStruct.HSI48State = RCC_HSI48_ON;
RCC_OscInitStruct.PLL.PLLM = RCC_PLLM_DIV1;
RCC_OscInitStruct.PLL.PLLN = 16;
Error_Handler();
|RCC_CLOCKTYPE_PCLK1;
if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
Error_Handler();
#ifdef __cplusplus
#endif /* ARDUINO_EBB42_V1_1 */
* Copyright (c) 2020, STMicroelectronics
#pragma once
* STM32 pins number
#define PA0 PIN_A0
#define PA1 PIN_A1
#define PA2 PIN_A2
#define PA3 PIN_A3
#define PA4 PIN_A4
#define PA5 PIN_A5
#define PA6 PIN_A6
#define PA7 PIN_A7
#define PA8 8
#define PA9 9
#define PA10 10
#define PA11 11
#define PA12 12
#define PA13 13
#define PA14 14
#define PA15 15
#define PB0 PIN_A8
#define PB1 PIN_A9
#define PB2 PIN_A10
#define PB3 19
#define PB4 20
#define PB5 21
#define PB6 22
#define PB7 23
#define PB8 24
#define PB9 25
#define PB10 PIN_A11
#define PB11 PIN_A12
#define PB12 PIN_A13
#define PB13 29
#define PB14 30
#define PB15 31
#define PC6 32
#define PC7 33
#define PC13 34
#define PC14 35
#define PC15 36
#define PD0 37
#define PD1 38
#define PD2 39
#define PD3 40
#define PF0 41
#define PF1 42
#define PF2 43
#define PA9_R 44
#define PA10_R 45
// Alternate pins number
#define PA1_ALT1 (PA1 | ALT1)
#define PA2_ALT1 (PA2 | ALT1)
#define PA3_ALT1 (PA3 | ALT1)
#define PA4_ALT1 (PA4 | ALT1)
#define PA6_ALT1 (PA6 | ALT1)
#define PA6_ALT2 (PA6 | ALT2)
#define PA7_ALT1 (PA7 | ALT1)
#define PA7_ALT2 (PA7 | ALT2)
#define PA7_ALT3 (PA7 | ALT3)
#define PA9_ALT1 (PA9 | ALT1)
#define PA9_R_ALT1 (PA9_R | ALT1)
#define PA10_ALT1 (PA10 | ALT1)
#define PA10_R_ALT1 (PA10_R | ALT1)
#define PA14_ALT1 (PA14 | ALT1)
#define PA15_ALT1 (PA15 | ALT1)
#define PB0_ALT1 (PB0 | ALT1)
#define PB1_ALT1 (PB1 | ALT1)
#define PB1_ALT2 (PB1 | ALT2)
#define PB3_ALT1 (PB3 | ALT1)
#define PB4_ALT1 (PB4 | ALT1)
#define PB5_ALT1 (PB5 | ALT1)
#define PB6_ALT1 (PB6 | ALT1)
#define PB6_ALT2 (PB6 | ALT2)
#define PB7_ALT1 (PB7 | ALT1)
#define PB8_ALT1 (PB8 | ALT1)
#define PB9_ALT1 (PB9 | ALT1)
#define PB13_ALT1 (PB13 | ALT1)
#define PB14_ALT1 (PB14 | ALT1)
#define PB15_ALT1 (PB15 | ALT1)
#define PB15_ALT2 (PB15 | ALT2)
#define PC6_ALT1 (PC6 | ALT1)
#define PC7_ALT1 (PC7 | ALT1)
#define NUM_DIGITAL_PINS 46
#define NUM_REMAP_PINS 2
#define NUM_ANALOG_INPUTS 14
// On-board LED pin number
#ifndef LED_BUILTIN
#define LED_BUILTIN PNUM_NOT_DEFINED
// On-board user button
#ifndef USER_BTN
#define USER_BTN PNUM_NOT_DEFINED
// SPI definitions
#ifndef PIN_SPI_SS
#define PIN_SPI_SS PA4
#ifndef PIN_SPI_SS1
#define PIN_SPI_SS1 PA15
#ifndef PIN_SPI_SS2
#define PIN_SPI_SS2 PB0
#ifndef PIN_SPI_SS3
#define PIN_SPI_SS3 PNUM_NOT_DEFINED
#ifndef PIN_SPI_MOSI
#define PIN_SPI_MOSI PA2
#ifndef PIN_SPI_MISO
#define PIN_SPI_MISO PA6
#ifndef PIN_SPI_SCK
#define PIN_SPI_SCK PA1
// I2C definitions
#ifndef PIN_WIRE_SDA
#define PIN_WIRE_SDA PA6
#ifndef PIN_WIRE_SCL
#define PIN_WIRE_SCL PA7
// Timer Definitions
// Use TIM6/TIM7 when possible as servo and tone don't need GPIO output pin
#ifndef TIMER_TONE
#define TIMER_TONE TIM6
#ifndef TIMER_SERVO
#define TIMER_SERVO TIM7
// UART Definitions
#ifndef SERIAL_UART_INSTANCE
#define SERIAL_UART_INSTANCE 4
// Default pin used for generic 'Serial' instance
// Mandatory for Firmata
#ifndef PIN_SERIAL_RX
#define PIN_SERIAL_RX PA1
#ifndef PIN_SERIAL_TX
#define PIN_SERIAL_TX PA0
// Extra HAL modules
#if !defined(HAL_DAC_MODULE_DISABLED)
#define HAL_DAC_MODULE_ENABLED
* Arduino objects - C++ only
#ifdef __cplusplus
// These serial port names are intended to allow libraries and architecture-neutral
// sketches to automatically default to the correct port name for a particular type
// of use. For example, a GPS module would normally connect to SERIAL_PORT_HARDWARE_OPEN,
// the first hardware serial port whose RX/TX pins are not dedicated to another use.
// SERIAL_PORT_MONITOR Port which normally prints to the Arduino Serial Monitor
// SERIAL_PORT_USBVIRTUAL Port which is USB virtual serial
// SERIAL_PORT_LINUXBRIDGE Port which connects to a Linux system via Bridge library
// SERIAL_PORT_HARDWARE Hardware serial port, physical RX & TX pins.
// SERIAL_PORT_HARDWARE_OPEN Hardware serial ports which are open for use. Their RX & TX
// pins are NOT connected to anything by default.
#ifndef SERIAL_PORT_MONITOR
#define SERIAL_PORT_MONITOR Serial
#ifndef SERIAL_PORT_HARDWARE
#define SERIAL_PORT_HARDWARE Serial
