firmware update
hyur
firmware update
Post by hyur »
hello experts
I have a question about updating the firmware, so I left a question.
I want to proceed with the current firmware update through USART.
I would like to make the BOOT0 pin HIGH only when updating firmware and lower BOOT0 to LOW otherwise.
I don't want to set this as a physical jumper (Like bluepill).
If you have a common method, please give me an idea.
For reference, I use STM32F103RDT6.
Re: firmware update
There is no other way than physically pull BOOT0 pin to VDD.
If you don't want to use a jumper or button or switch, you can always use another MCU that will output high signal to BOOT0 pin.
hyur
Re: firmware update
Post by hyur »
@GonzoG
HIGH rises only when firmware update is in progress
Do you have a pin?
If there is such a pin, I would like to connect it.
Vassilis
Re: firmware update
Post by Vassilis »
@hyur
Maybe the STM32-Programmer is what you want.
https://www.mikrocontroller.net/topic/141711
Vassilis Serasidis
https://www.serasidis.gr
