Applications uploaded to the Seeed Studio LoRa-E5 mini does not boot
larswd
Post by larswd »
My supervisor and I have been trying to do some work using the Seeed studio board LoRa-E5 mini using STM32WLE5JC.
After struggling a bit with removing the included write protection using the STM Programmer and a ST-Link, we managed to upload a script to the board. While we can, indeed see that the script has been uploaded, see picture attached below, the board seems to be entirely unresponsive. We can neither detect any activity on the connected serial ports, nor does the builtin LED flash (Code included below). We have also tried this on two boards, making it more unlikely to be caused by faulty hardware. The only response we have been able to get is that the RX LED flashes briefly if we send messages to it using the Arduino IDE (v2) serial monitor.
Has anyone encountered similar problems to ours?
Image showing that data has been uploaded to the controller: (We have also found machine instructions for writing to serial and blinking the built in LED in the system memory)
larswd
Re: Applications uploaded to the Seeed Studio LoRa-E5 mini does not boot
Post by larswd »
The script we uploaded was a standard blink-script, namely
#include <Arduino.h>
delay(100);
Serial.println(F("booted"));
pinMode(LED_BUILTIN, OUTPUT); //We have tried using the exact pin name as well
delay(2000);
Serial.println(F("loop"));
I guess you used the Generic WLE5JCIx target ?
So the LED_BUILTIN is simply undefined as a generic is not a board so don't know which pin to used. It is defined to allow build in CI.
// On-board LED pin number
[code]#ifndef LED_BUILTIN
  #define LED_BUILTIN           PNUM_NOT_DEFINED
[/code]
Up to you to define it to the correct pin of the board.
You can redefine it using build_opt.h: https://github.com/stm32duino/Arduino_C ... uild_opt.h
with
 -DLED_BUILTIN=xx
Same for Serial, default port is defined with:
// UART Definitions
#ifndef SERIAL_UART_INSTANCE
  #define SERIAL_UART_INSTANCE  101
// Default pin used for generic 'Serial' instance
// Mandatory for Firmata
#ifndef PIN_SERIAL_RX
  #define PIN_SERIAL_RX         PA3
#ifndef PIN_SERIAL_TX
  #define PIN_SERIAL_TX         PA2
See https://github.com/stm32duino/Arduino_C ... wareserial
larswd
Post by larswd »
Thank you for the reply, and sorry for the late answer. The notification probably disappeared into some inbox. We managed to make it work, and while the pin target had to be changed, the main issue, I think, was something else. I have written a step-by-step-guide here outlining how we got it to work with functional code.
https://github.com/larswd/STM32WL-Seeed ... Playground
