Unable to see any output from serial monitor
HelloWorld
Post by HelloWorld »
Good day to everyone here, i am a beginner for nucleo l073rz (connected with I-nucleo-LRWAN1) and for the past 3 days, i have been trying to see my output from my serial monitor, but to no avail, nothings shows up.
  Serial.begin(115200);  // Initialize serial communication with a baud rate of 115200
  Serial.println("Hi");  // Print "Hi" to the serial monitor
  delay(1000);           // Wait for 1 second
These are the codes that i have been trying. If I toggle the builtin led, it works. But if i try to println something, it just does not work.
settings:
board 64
com 15 (exactly my l073rz port)
board part number l073rz
upload method = mass storage
enabled generic serial
Serial monitor baud rate = 115200
I have set the settings as above and still to no avail, i get no Hi from my serial monitor even though the debugging and build are success
Answers: 92
Re: Unable to see any output from serial monitor
I've tested and it works.
You should check if the STLink Rx/Tx are connected thanks jumper on CN2 connector.
Else with I Nucleo LRWAN, pay attention to the hardware configuration as be default it assumes having Serial connected to D0/D1.
Bue default config of the Nucleo boards was to not having pins connected to the connector.
https://github.com/stm32duino/I-NUCLEO- ... imitations
So maybe you alread rework your board and close SB then it could explain Serial does not works as expected as also connected to shield.
HelloWorld
Sadly,I am not using l073rz anymore as I'm using nucleo f411re to display the output in serial monitor...
