TTGO ESP32, OLED, & Battery
Anything not related to STM32
mrmonteith
Post by mrmonteith » Wed Sep 06, 2017 2:51 pm
I bought one of these. It has a label TTGO and has a holder for a 18650 battery on the back and OLED.
However I'm not sure which display chip it uses. Just curious in case someone knows right off? I'm thinking ssd1306 as a possibility. If nothing else I'll load those drivers and see if it works. What others might it be?
Also not sure what board to select. I may have to dig around since I'm new to the WROOM-32 modules.
Michael
mrmonteith
Re: TTGO STM32, OLED, & Battery
Post by mrmonteith » Wed Sep 06, 2017 3:25 pm
RIght now I'm looking through Roger's videos and working through that first to get a basic sketch going.
Michael
Rick Kimball
Post by Rick Kimball » Wed Sep 06, 2017 3:37 pm
Isn't that an esp32 not a stm32?
-rick
mrmonteith
Post by mrmonteith » Wed Sep 06, 2017 3:50 pm
My bad. Yes. It's ESP32.
mrmonteith
Re: TTGO ESP32, OLED, & Battery
Post by mrmonteith » Wed Sep 06, 2017 5:20 pm
I was able to get it all connected and running a blink sketch on it. Now to try the display drivers.
Michael
mrmonteith
Post by mrmonteith » Wed Sep 06, 2017 7:02 pm
This will take some time. Not sure how the display is connected. Poke and hope I guess.
Michael
mrmonteith
Post by mrmonteith » Wed Sep 06, 2017 7:38 pm
Well I found a site that had this board. I had to use Google translation. But at least found a pinout diagram that showed what I needed. If this board works out it will be pretty nice since it has a battery holder on the back side. Also a switch to turn off the display if you don't need it.
zmemw16
Post by zmemw16 » Wed Sep 06, 2017 9:23 pm
a link if you please :)
it could also be spi or i2c as well
ssd1306? isn't there a sh11xx or similar.
browse the adafruit github repository, it got a few display types listed :D
stephen
quick aliexpress - they all seem to use the same photos & blurb, overview link is for esp32 itself.
mrmonteith
Post by mrmonteith » Wed Sep 06, 2017 9:37 pm
https://de.aliexpress.com/store/product ... 2878neRVWq
It was I2C and using the SSD1306 drivers worked. There is a 1106. When I installed the SSD1306 driver library it contains both.
It showed on pinout diagram which pin was SDA and SCL.
Michael
Spiessa
Post by Spiessa » Tue Oct 24, 2017 6:00 am
Unfortunately, your link does not work anymore. Which pins were used for SDA and SCL?
Andreas
