NuttX on a BluePill
Anything not related to STM32
acassis
Re: NuttX on a BluePill
Post by acassis » Wed Sep 20, 2017 11:32 pm
Pito wrote:
Wed Sep 20, 2017 3:09 pm
This is the way I created a shell script "mrdisk" for creating a ramdisk :) without an editor available..
Copy and paste work perfectly in TeraTerm, set NewLine to CR/CR. I've also set 256chars per line via menuconfig.
Fantastic stuff the ">" and ">>" work here!
nsh> echo "mkrd -m 1 -s 512 800" >> /sdcard/mrdisk
nsh> echo "mkfatfs /dev/ram1" >> /sdcard/mrdisk
nsh> echo "mount -t vfat /dev/ram1 /ramdisk" >> /sdcard/mrdisk
nsh> cat /sdcard/mrdisk
mkfatfs /dev/ram1
nsh>
nsh> sh /sdcard/mrdisk
nsh>
nsh> df
  Block  Number
  Size   Blocks     Used Available Mounted on
   512      761        2       759 /ramdisk
 32768   485936     3179    482757 /sdcard
nsh>
What is nice you can copy and paste the entire block - like
mount -t vfat /dev/mmcsd0 /sdcard
mkfatfs /dev/ram1
df
into the terminal (115k2 here), with Linux or Win line endings, and with 0 (zero !!!) char and line transmit delays, and you get
NuttShell (NSH)
No MOTD string provided
nsh> mount -t vfat /dev/mmcsd0 /sdcard
nsh> mkrd -m 1 -s 512 800
nsh> mkfatfs /dev/ram1
nsh> mount -t vfat /dev/ram1 /ramdisk
nsh> df
  Block  Number
 32768   485936     3178    482758 /sdcard
nsh>
:shock: Great!!
The best way to have initialization scripts is creating a ROMFS that will be mounted at /etc with the file /etc/init.d/rcS that will be executed after the system boot. See here: http://nuttx.org/Documentation/NuttShel ... rtupscript
Squonk42
Post by Squonk42 » Fri Sep 22, 2017 6:29 am
@acassis: thank you for your video tutorials, they are great!
I had a small problem while flashing a Bluepill fresh out of its anti-static bag: I got this error message from openocd:
Error: stm32x device protected
I solved this issue by sending:
openocd -f interface/stlink-v2.cfg -f target/stm32f1x.cfg -c init -c "reset halt" -c "stm32f1x unlock 0" -c "reset halt"
I try to use the Bluepill as an I2C slave device, like an I2C extension to an RPi (or any other xPi). I am not able to have it working ith Arduino, and I wonder if this could work with NuttX? I would implement a simple I2C command switch to perform GPIO read/write, PWM, etc.
acassis
Post by acassis » Fri Sep 22, 2017 11:39 am
Hi Squonk42,
NuttX has the callbacks to support I2C Slave: include/nuttx/i2c/i2c_slave.h, but AFAIK nobody implemented the I2C Slave driver yet.
You will need to take a look at www.st.com/resource/en/application_note/cd00209826.pdf to understand how it works and how to implement it. It should be a good contribution case you decide to carry on with this idea.
Post by Pito » Fri Oct 20, 2017 8:08 am
@Alan: does the NuttX support hotswapping of the Sdcard when the Card Detect signal is available on the socket?
Like mount/umount -> hotswap -> mount..
Here without Card Detect signal (I do not have the signal on my socket available).
nsh> ls -l /sdcard
/sdcard:
 -rw-rw-rw- 8388608 STM32Demo.bin
nsh> umount /sdcard
nsh> ls -l /sdcard
nsh: ls: stat failed: 2
nsh> ls -l /sdcard
/sdcard:
 -rw-rw-rw- 8388608 XXXX.bin
nsh> umount /sdcard
nsh> ls -l /sdcard
nsh>                                   <<<<<<<<<<<<< SDCARD HOTSWAPPED
nsh: mount: mount failed: 19
nsh> ls -l /dev
/dev:
 crw-rw-rw-       0 console
 brw-rw-rw-       0 mmcsd0
 crw-rw-rw-       0 null
 crw-rw-rw-       0 ttyS0
 crw-rw-rw-       0 urandom
 crw-rw-rw-       0 zero
nsh>
Also, can we mount several sdcards?
