Breadboard wire
Anything not related to STM32
Kenjutsu
Breadboard wire
Post by Kenjutsu » Sun Sep 17, 2017 2:34 pm
Hello everyone,
I want to buy single/solid core wire to make my own custom length wires when wiring up a project on a breadboard. Searching on AliExpress gives mixed results, so I was wondering, will the following work:
8colors PCB P/N 30AWG Wrapping Wire 250meter Flying Jumper 820FT Multicolor Cable Ok Wire DM-30-1000
Or, alternatively, for what should I search for on AliExpress to get the right selection of wire?
Thank you ;)
Pieter
OSX: 10.12.6
Arduino IDE: 1.6.12
Blue pill STM32F103C8T6 Dev Board
Maple Mini Clones
zmemw16
Re: Breadboard wire
Post by zmemw16 » Sun Sep 17, 2017 2:51 pm
only if you plan to wire-wrap your connections :lol:
i think it's more like 20 or 22 gauge is needed :?: :?:
stephen
Pito
Re: Breadboard wire
Post by Pito » Sun Sep 17, 2017 3:00 pm
I've got several meters of cat-5 patch cable (solid wires inside) and using them on my solderless breadboards. The wire is not tinned, but that is not a big problem..
wiki:
Since 1995, solid-conductor UTP cables for backbone cabling is required to be no thicker than 22 American Wire Gauge (AWG) and no thinner than 24 AWG, or 26 AWG for shorter-distance cabling.
zmemw16
Re: Breadboard wire
Post by zmemw16 » Sun Sep 17, 2017 3:11 pm
istr typically using CCA copper coated aluminum
srp
Pito
Re: Breadboard wire
Post by Pito » Sun Sep 17, 2017 4:15 pm
The digital signals are pulses with ~hundreds of megahertz frequency spectra (because of the signal edges) - those frequencies are pushed into a few microns thin layer at the surface (skin effect) which is made of copper - no problem for our duino-breadboards wiring :) Also I can hardly imagine a 10m long wire used on the breadboard :)
https://en.wikipedia.org/wiki/Skin_effect
Copper Skin Effect.JPG (27.17 KiB) Viewed 239 times
Kenjutsu
Re: Breadboard wire
Post by Kenjutsu » Thu Sep 21, 2017 6:26 am
Thanks @Pito 8-) Just wished they had more color options ;)
Pieter
OSX: 10.12.6
Arduino IDE: 1.6.12
Maple Mini Clones
