Linux Journal
Anything not related to STM32
racemaniac
Re: Linux Journal
Post by racemaniac » Wed Dec 06, 2017 4:05 pm
ag123 wrote:
Wed Dec 06, 2017 3:03 pm
there is something common between linux, arduino, stm32duino
and it is actually more than open source
the first time when i installed a linux distribution on a *386* pc using *floppies*, the most amazing and fun thing then is that 'i've my own (un*x) os', back then un*x used to be run on expensive dec, sun, apollo and sgi workstations, having linux (un*x) on a pc is 'disruptive* it changed the status quo. no longer is windows and ms dos the only (public) desktop os. i can run my own mail server, domain name server etc, back then in the windows world it is a privilege of the 'servers' unless of course one downloads and run shareware / freeware versions of those.
back then and for a long time connecting to diy custom peripherals is pretty much rs232 16550 uart etc. then come usb, and for the longest time there is no 'user custom-able usb', vlsi are expensive short of buying in bulk. many resort to usb-serial converters. today comes leaflabs maple, stm32duino it is 'disruptive' in a similar light, user customizable usb is now a reality. a blue pill, maple mini's role can be simply re-defined uploading a sketch or firmware. in a sense stm32 could just 'spoof' any usb vid/pid and mimic whatever device one deems fit. similarly with things like nrf51822 makes bluetooth le 'user customizable'. i'm not sure how long this niche trend would last, but i'd guess this is part of that 'iot' hype along with the RPis, beaglebone blacks, arduinos, micro:bit, and all that n variety of mcu boards and single board computers.
but i'd guess 'iot' is simply a buzzword to the 'average' man on the street probably ignored just as the 'average' crowd seemed pretty happy with the notion that computers runs windows, phones runs android or ios, while things like linux, arduino (etc) simply co-existed below the 'noise floor'
OT: on a side note things like stm32duino could literally outdo the million monkey theorem
https://en.wikipedia.org/wiki/Infinite_monkey_theorem
with the help of things like AI, deep learning etc, stm32duino could simply mimic a 3 in 1 device usb serial, keyboard, mice, it receives 'AI' instructions over usb serial, spoofs as the keyboard and mice and conjure the works of an other worldly william shakespheare
As someone who's a bit more in between, i have some linux devices and don't mind interfacing with them, but usually uses windows, i think the problem with a lot of open source programs for "normal people" is that people also value their time (and in some cases sanity).
Open source still seems to have very little motivation to make things usable to everybody. And usually when asking around, everything is possible with open source software, until you actually try to do it, and end up having to compile your own recent drivers, messing around with version hell on certain components, getting stuck for hours in obscure config files and getting 3 different tools to work together somehow, and then giving up because it's all just falling apart (may or may not reflect some of my past experiences).
I have a certain interest in linux/unix, but until i actually want to learn/investigate it as a hobby, it'll just be what's deep down in my android phone, NAS servers, raspberry pi, and i'll just use it very superficially with things i know work well, not trying too fancy things (which i know i can easily achieve on windows).
It also depends on how you like working, i know people who adore CLI interfaces, hack everything together using scripts, etc... if that's your thing, go for it :). i grew up with ms dos -> windows 3.1 -> windows 95. and for me it always felt like an improvement, and i like where it is now :).
And for all the goods & evils about microsoft etc... There are some obvious evils, but so far they haven't bitten me too much yet (and luckily in europe the EU fights back when corporations go too far). Some of the goods i like is that they are very driven to make things usable, compatible across the entire system, great backwards compatibility, and a lot of effort in continuous improvement of their ecosystem.
Re: Linux Journal
Post by ag123 » Wed Dec 06, 2017 4:39 pm
i'm not really anti-(ms) windows for that matter, just that i find that linux, un*x apparently seemed suitable for different purposes / use cases.
when one tries to build scripts / have some simple batch automations etc, i tend to find linux , unix shells and tools more versitle.
for a programming environment e.g. with eclipse, arduino etc i tend to find various open sourced tools well developed and suited to the linux environment e.g. dfu-util which we used to flash the sketches. it tends to 'work out of box', my guess is in part it is built around libusb which is pretty much a mature single library in the linux world. in addition, for development, linux distributions comes with a rich set of tools such as make files etc which simplified things before IDEs become commonly available on linux as well. the open sourced environment also tends to 'hide little' between the hardware and os (pretty much close to bare metal), you could pretty much observe the logs out right e.g. running lsusb, checking dmesg etc when troubleshooting connectivity problems e.g. with a blue pill / maple mini etc. i'm thinking that on windows, sometimes it isn't as easy to troubleshoot and diagnose usb connectivity issues as the logs/hints may not be there or may be rather obscure.
there are other use cases such as intel compute stick, on windows it pretty much works as a 'tiny desktop' computer.
it is actually rather inconvenient if u discover that to use the compute stick you'd need to hook up a monitor, keyboard, mouse, a usb hub (it has only one port) and power to basically use it as a little desktop pc.
with linux i turned it into a remote device in which i can remotely control and run pretty much anything over wifi
https://liliputing.com/2015/07/simplest ... o-far.html
and with some of those dlna clients
https://elinux.org/DLNA_Open_Source_Projects
or kodi
https://kodi.tv/
i could stream videos to it just like a chromecast dongle
Re: Linux Journal
Post by zmemw16 » Wed Dec 06, 2017 5:17 pm
a strange thing i like about the internet is a quote from somewhere
"censorship is interpreted as damage and is to be routed around"
ok probably not totally true anymore.
i remember being on the phone for guidance whilst doing the 3.5 hr kernel compile and also the 15 3.5" non floppies to install slackware and i think a 0.98 kernel, 386sx16 over clocked to 20, 2mb of sip, hercules graphics card. £1317 istr, someone at the time crowed about getting his £10 cheaper.
the guy distributing it had to do the copying them quietly in the student computing area of Aston Uni and i had the train journey to wait for and collect them.
something about linux hardware, wait and it will work; bit like censorship in the above :)
where's my barcode reader, anyone remember Tandy ... ... yes it did eventually and that was enough for me !
Re: Linux Journal
Post by mrburnette » Wed Dec 06, 2017 5:54 pm
Well, I am... anti-MS. I spent many years as a MCSE Windows-role architect and have thousands of Windows automated installations under my belt and years of 3rd and 4th level engineering support.
... Rick's screwed up royally. ... he went to reply and inadvertently edited instead .. I'm so sorry Ray
Nah... no problem Rick... beware the edit icon :lol:
... To elaborate in a weebit less words than the original: Wife's PC broke Jan 2016 and I bought a 2nd hand refurbished notebook and installed Linux Mint 17.x on the box. She had 23 years of Windows experience at work and she move to Linux @home with no issues... I did not get yelled at even once. :mrgreen: She edits WP and spreadsheets in Open Office and moves files between Windows 8.1 and Linux Mint without any concerns.
Here is the punch line:
If my 66 YO wife can move from Windows to Linux, anyone in this forum can too. Just bite the bullet, convert, and stop all the rediculous bla, bla, bla excuses ... or, would you like everyone to know you were passed in the techno fast lane by a granny?
Just do it.
Re: Linux Journal
Post by ag123 » Wed Dec 06, 2017 6:17 pm
oh well, either way, it'd seem m$ and even the os itself is going the 'cloud' route these days, a trouble is many commercial s/w vendors still continue to do 'windows only', and oh yeah, they'd basically support 1 h/w platform and maybe even 1 os level (say windows 10), if windows 11 comes along good luck or maybe u can buy another new s/w package from them ('upgrade')
racemaniac
Re: Linux Journal
Post by racemaniac » Wed Dec 06, 2017 6:38 pm
I read your full post, and i see where you're coming from. Luckily a lot of the things you're mentioning have improved (it also reflects how the pc industry evolves). Windows 10 runs great on older systems etc... not like the windows 95 -> windows vista era where every consecutive windows indeed basically required a new pc...
Re: Linux Journal
Post by zmemw16 » Wed Dec 06, 2017 7:46 pm
work wise didn't have much choice, then someone said want to build a test rig and i sold them linux for the license fees. :D
linux boxes, kernel, isa & pci device drivers AND i get paid. :D :lol:
system unit was pretty much a display, mouse and keyboard less laptop, take home and connect ... ...
back in next day and connect ... ...
best 5yrs, even better i was able to carry on using a linux box.
seems some people thought i'd be bored senseless with one on my desk.
they didn't quite get the unix do one thing well and pipe approach, aka divide and conquer, i almost got fond of Perl5; they still favour monolithic c++ app approach.
Re: Linux Journal
Post by mrburnette » Wed Dec 06, 2017 8:43 pm
... tools that live in the Windows only world can almost always run in a VM.
Example:
cypress_linux_tools - Tools to build and flash cypress PSoC Creator projects under Linux. ... gengetopt; make; wine (to run cyelftool when using makefile); An arm toolchain (arm-none-eabi-). In order to build and install ...
Simple Win32 API stuff often runs under Wine which is often part of Linux base installations.
When all else fails, dual boot...
Re: Linux Journal
Post by ag123 » Thu Dec 07, 2017 2:00 am
ot again: on a side note, i'm wanting to try to make arudino make files that'd build my sketches in linux with or without eclipse.
it is one of those 'projects' that i wanted to do but never seem to be able to dedicate time to it.
linux distributions normally has all the tools for a make file based build. on windows i'd think u'd at least need to get things like visual c++ or some c based compilers and packages. and i'd guess normally 'IDE' seem to be the norm these days on windows and makefiles are 'delegated' to the linux / un*x world.
the benefit of make files? copy the whole project change a few lines in the make file and different sets of libraries gets included, all the default defines and includes could be pre-defined 'arduino ide' isn't needed for that
and building a binary/sketch is simply 'make'
Re: Linux Journal
Post by mrburnette » Thu Dec 07, 2017 3:44 am
https://github.com/sudar/Arduino-Makefile
This is a very simple Makefile which knows how to build Arduino sketches. It defines entire workflows for compiling code, flashing it to Arduino and even communicating through Serial monitor. You don't need to change anything in the Arduino sketches.
Features
Very robust
Highly customizable
Supports all official AVR-based Arduino boards
Supports chipKIT
Supports Teensy 3.x (via Teensyduino)
Works on all three major OS (Mac, Linux, Windows)
Auto detects serial baud rate and libraries used
Support for *.ino and *.pde sketches as well as raw *.c and *.cpp
Support for Arduino Software versions 0.x, 1.0.x, 1.5.x and 1.6.x except 1.6.2. We recommend 1.6.3 or above version of Arduino IDE.
Automatic dependency tracking. Referred libraries are automatically included in the build process. Changes in *.h files lead to recompilation of sources which include them
Installation
Through package
Using apt-get (or aptitude)
If you're using FreeBSD, Debian, Raspbian or Ubuntu, you can find this in the arduino-mk package which can be installed using apt-get or aptitude.
sudo apt-get install arduino-mk
I also think Rick or another Linux member posted about Linux make
