Arduino Based Lightsaber With Light and Sound Effects
Anything not related to STM32
Post by zmemw16 » Sun Dec 17, 2017 4:24 pm
racemaniac
Re: Arduino Based Lightsaber With Light and Sound Effects
Post by racemaniac » Sun Dec 17, 2017 6:07 pm
nice :)
i'm impressed he managed to do all that on an arduino XD.
i'm already having trouble doing all that on an stm32 XD
Post by RogerClark » Sun Dec 17, 2017 9:20 pm
@racemaniac
I suspect the WAV files must be lower resolution that the ones you are using, and perhaps one sound file at a time.
from what I have read in your posts, you are doing a lot if complicated files processing of sounds
Edit. I cant see a DAC etc in the BOM for that AVR lightsabre, so the audio is not going to very good quality
racemaniac
Post by racemaniac » Mon Dec 18, 2017 6:24 am
@racemaniac
indeed, he'll have to compromise on various things, but it's still impressive to stream 1 wav file from an sd card on only 2kb of ram of the arduino :)
Post by RogerClark » Mon Dec 18, 2017 6:51 am
Yes. Very impressive that he is able to stream a wav
racemaniac
Post by racemaniac » Mon Dec 18, 2017 8:56 am
unless he assumes the file is not fragmented, just basic double buffering already requires 1.5kb (512bytes per buffer, and 1 buffer for the FAT table so you know where your next block is) (and the buffers should be 512 bytes as that is the blocksize of FAT)
if i find some time i'll have a look at his code, i'm wondering how it works :).
