Reading serial monitor in bluepill using esp8266
Anything not related to STM32
peeknot
Post by peeknot » Thu Feb 01, 2018 2:18 pm
Im using node mcu v3 in arduino ide , is there any code snippet for reading the serial monitor from bluepill to node?
Bluepill Node Mcu
PB10(TX)----->RX
GND----------->GND
or any idea how to do it? thanks for the answers
Re: Reading serial monitor in bluepill using esp8266
Post by mrburnette » Thu Feb 01, 2018 9:53 pm
The easiest way to test is with a USB-serial module and a PC.
It is very close to Arduino in implementation. Just remember that unless you implement flow-control, the basic approach is just to buffer and at high speeds, your buffer could overflow unless you ensure you are polling the status often enough.
http://arduino-esp8266.readthedocs.io/en/latest/
This may be relevant: https://forum.arduino.cc/index.php?topic=333118.0
I read the keyboard over USB for a NodeMCU here: https://www.hackster.io/rayburne/oui-ou ... 66-323ae4
UPDATE: http://robotic-controls.com/learn/ardui ... munication
zoomx
Post by zoomx » Fri Feb 02, 2018 8:27 am
