A better ESP-32 multasking example
Anything not related to STM32
Post by mrburnette » Mon Feb 12, 2018 2:05 am
Was I missed on the forum this weekend? :lol: I thought not.
I spent some time messing around with the ESP-32 under Arduino. I got the < $5 Wemos Lite board in from AliExpress and I can remember when the Maple Minis were this price just a few years ago.
So, my playtime (limited on weekends) was devoted to reading about Espressif's implemation of FreeRTOS with their Arduino core. I watched a couple of YouTube videos. I read one too many articles. I tried several examples. My head started to hurt because this is such a simple concept and existing Arduino examples were really poor. Worst, some were missing the fact that the Arduino code creates a default task; that is, in standard mode, Arduino runs on one core and the RF native side runs on one core.
Said another way, one can cycle-steal from the RF "dedicated" core since the Arduino side already has a dedicated core.
I created a multi-tab Arduino project to easily demonstrate how simple the overall process can be. The code is available as a ZIP from my project page:
https://www.hackster.io/rayburne/esp32- ... res-8dd948
Enjoy.
The three user's task: 0, 1, 2:
__task__                  __core__
Task 1 complete running on Core 0 Time = 2 mS
Task 2 complete running on Core 1 Time = 1 mS
Task 0 complete running on Core 1 Time = 1 mS
Task 1 complete running on Core 0 Time = 1 mS
Task 2 complete running on Core 1 Time = 2 mS
Task 0 complete running on Core 1 Time = 2 mS
Re: A better ESP-32 multasking example
Post by RogerClark » Mon Feb 12, 2018 4:42 am
Sounds interesting...
I like the idea of being able to use both cores.
WindyYam
Post by WindyYam » Mon Feb 12, 2018 6:19 am
Well it's amazing that we can buy such a powerful soc/mcu arduino ready board with that crazy low price.
I think it would definitely outperforms stm32f4 even on computationally intensive applications.
Slammer
Post by Slammer » Mon Feb 12, 2018 11:52 am
Andreas Spiess has released a great video about using the 2 cores of ESP32. It is here: https://youtu.be/k_D_Qu0cgu8
The ESP32 is really a very powerfull device for the price. Even without Wifi/Bluetooth capabilities is a very cost effective chip.
Post by mrburnette » Mon Feb 12, 2018 12:48 pm
The "basics of the code example" was from watching the Spiess video. But his example was convoluted, IMO. I kept his "workload" and reworked much of the format, etc. Andreas was only alternating core 0, 1 but the ZIP example actually makes use of the loop() to show that time slicing is also allocated to that task too.
So, to summarize, if you add 2 tasks, one to Core0 and one to Core1, then there are 4 tasks running:
  • RF and protocols on core0
  • User loop() on core1
  • User added task on core0
  • User added task on core1
The above are properly handled in my reworking of Andreas's example code... Additionally, I corrected the over use of global variables and properly moved the functions outside the main sketch into their own tabs with proper prototyping.
TAB DualCore
   This sketch runs the same load on both cores of the ESP32
   ArduinoIDE 1.8.5
   Linux Mint 18.3
    Sketch uses 162569 bytes (12%) of program storage space. Maximum is 1310720 bytes.
    Global variables use 11068 bytes (3%) of dynamic memory, leaving 283844 bytes for local variables. Maximum is 294912 bytes.
#include <Streaming.h>      // Ref: http://arduiniana.org/libraries/streaming/
#include "Workload.h"
#include "Task1.h"
#include "Task2.h"
TaskHandle_t TaskA, TaskB;
  delay(500);  // small delay
  // Ref: http://esp32.info/docs/esp_idf/html/db/da4/task_8h.html#a25b035ac6b7809ff16c828be270e1431
  xTaskCreatePinnedToCore(
    Task1,                  /* pvTaskCode */
    "Workload1",            /* pcName */
    1000,                   /* usStackDepth */
    NULL,                   /* pvParameters */
    1,                      /* uxPriority */
    &TaskA,                 /* pxCreatedTask */
    0);                     /* xCoreID */
    Task2,
    "Workload2",
    1000,
    NULL,
    1,
    &TaskB,
    1);
  // This task will run in the ESP32 Arduino default context
  unsigned long start = millis();
  Serial << "Task 0 complete running on Core " << (xPortGetCoreID()) << " Time = " << (millis() - start) << " mS"  << endl ;;
  delay(10) ;
TAB Task1.h
void workLoad (void) ;                // prototype is required
void Task1( void * parameter )
  for (;;) {
    unsigned long start = millis();   // ref: https://github.com/espressif/arduino-esp32/issues/384
    workLoad();
    Serial << "Task 1 complete running on Core " << (xPortGetCoreID()) << " Time = " << (millis() - start)<< " mS"  << endl;
    delay(10) ;
TAB Task2.h
void Task2( void * parameter )
  for (;;) {
    workLoad();
    Serial << "Task 2 complete running on Core " << (xPortGetCoreID()) << " Time = " << (millis() - start) << " mS"  << endl ;
    delay(10) ;
TAB Workload.h (Andreas Spiess code unchanged except for variable scoping and a few cast issues)
void workLoad (void) {
  unsigned long loops1 = 1000 ;
  unsigned long loops2 = 1000 ;
  unsigned long qq = 0 ;
  float t1;
  int t2;
  int t3;
  for ( long i = 0; i < loops1; i++) {
    for (long  j = 1; j < loops2; j++) {
      qq++;
      t1 = 5000.0 * i;
      t2 = 150 * 1234 * i;
      t3 = j % 554 ;
Post by zmemw16 » Mon Feb 12, 2018 1:55 pm
which route of software installation ?
i've got both the idf and sketchbook/hardware routes to compile, link and flash.
relatively painlessly as well.
i was actually thinking about asking for a zip from anyone with a working arduino, ~/sketchbook/hardware esp32 install.
i'm also thinking that the peripherals won't be as easy as on arduino, they don't seem to have a i2c scanner either :)
for breadboarding, have a look at my managing width post, viewtopic.php?f=17&t=3224
Post by mrburnette » Mon Feb 12, 2018 3:24 pm
The ESP32 core installation is straightforward. Follow directions.
The Lite board shipped with header pins... fits a breadboard perfectly... no adapter required. CH340C dedicate USB. Resets correctly from IDE.
There are many ESP32 examples once you get the core installed.
ESP32 Examples.jpg (144.66 KiB) Viewed 153 times
Post by zmemw16 » Mon Feb 12, 2018 3:53 pm
@Ray
have you tried the idf version ?
it brought back many memories of kernel configuring with it using 'make menuconfig', that started over quarter of a century ago :lol:
idf example hello world works a treat.
one thing i noticed was it needed a press on the reset button, even though the messages say it did a hard reset.
i had a quick 'look' at the i2c and spi examples, hence my comment.
Post by mrburnette » Tue Feb 13, 2018 7:44 pm
Have not worked directly in the IDF. Have used those function calls from within Arduino.
I have probably 5 different varieties of ESP32 modules. All reset after uploading using Linux Mint 18.3. ... have not tried under Windows.
Post by victor_pv » Tue Feb 13, 2018 10:16 pm
I thought I bought an ESP32, I need to try to find it and try some of this.
Quick question, can you have a task run in both core alternatively whenever one of them is available?
EDIT: Found my ESP32, is an ESP-WROOM with 4MB of extra RAM :) pretty nice for like $6-7.
