GD32F103VET6 board
Re: GD32F103VET6 board
Post by RogerClark » Mon Feb 29, 2016 10:07 pm
@cazimirb
Thanks.
Bad connections on micro USB is a very common problem.
Often these connectors break off the board :-(
I recommend that people put glue over the connector to hold it down. I use a hot glue gun, but epoxy glue etc also works well
Post by mrburnette » Tue Mar 01, 2016 2:47 am
cazimirb wrote: <...>
Now I can confirm that GD32F103VET6 is pin compatible with STM32F103VCT6 and works with GD32duino.
Now, this is cool to know.
Thx,
cazimirb
Post by cazimirb » Tue Mar 01, 2016 10:54 pm
After loading the GD32duino bootloader from STM32 ST-Link utility, I compiled and uploaded via USB a blink sketch from Arduino (selecting GD32F103C8 board).
Then, I tried again to connect the board via SWD, from STM32 ST-Link utility. The connection worked only after setting 'connect under reset' - pressing and releasing RESET while connecting to target. I couldn't connect otherwise..Maybe this info is helpful to someone..
Post by RogerClark » Tue Mar 01, 2016 11:05 pm
The reason you have to do connect under reset, is that the SWD pins get allocated as GPIO when the upload method is not STLink
So STLink will not connect, and you have to use connect under reset
If you upload directly to the board using STLink (no bootloader), then the SWD pins do not get allocated as GPIO, so you should not need to connect under reset
cazimirb
Post by cazimirb » Wed Mar 02, 2016 10:58 am
Got it, thanks Roger.
simonf
Post by simonf » Thu Jun 02, 2016 1:54 am
Looks like there's a reasonable priced dev board coming along to try this out $US6
https://world.taobao.com/item/524685248 ... 0.0.JPoGEX
It will be a while before it hits ebay/aliexpress (if it ever does)
Post by RogerClark » Thu Jun 02, 2016 2:08 am
You have to be brave to use TaoBao
Often the agents fees make things much more expensive than just doing a direct currency conversion from the price shown on TaoBao its self
simonf
Post by simonf » Thu Jun 02, 2016 2:27 am
RogerClark wrote: Often the agents fees make things much more expensive....
I had an agent about 15 years ago, He produced PC103 boards. I sent him a list of computer stuff I wanted and he would get bundle it all together and ship it. He usually negotiated a fee from the seller so often it did not cost me more than I had been quoted by the manufacturer, but we were talking combined orders of $20K+ .
I would not mind buying 100 blue pill GD32 boards If I could get them at a reasonable price I buy the blue pills in 20s. I could just stick em on ebay I am sure there is a premium to be had by their increased speed even @ 72MHz
