First pass at a BluePill Variant
Re: First pass at a BluePill Variant
Post by RogerClark » Mon Sep 19, 2016 8:28 am
How did you install the core ?
evge.05
Post by evge.05 » Mon Sep 19, 2016 9:45 am
like your core. Just copy files into /arduino/hardware/
Post by RogerClark » Mon Sep 19, 2016 10:01 am
OK
Can you confirm which URL you downloaded it from ?
evge.05
Post by evge.05 » Mon Sep 19, 2016 10:24 am
Post by RogerClark » Mon Sep 19, 2016 11:21 am
Um
Thats strange
I don't get that error
What version of the IDE are you running ?
evge.05
Post by evge.05 » Mon Sep 19, 2016 11:51 am
latest version 1.6.11
Post by Rick Kimball » Mon Sep 19, 2016 12:05 pm
https://github.com/RickKimball/Arduino_ ... /variant.h
PC13 is in that file.
Did you select the blue pill board or the nucleo?
evge.05
Post by evge.05 » Mon Sep 19, 2016 12:08 pm
select a nucleo board
Post by Rick Kimball » Mon Sep 19, 2016 12:09 pm
then you need to use whatever pin is for the led on that board in place of the PC13.
Post by Rick Kimball » Mon Sep 19, 2016 12:16 pm
I guess i should have used the define LED_BUILTIN however the way I wrote the code it was specific to the blue pill as it turns the led on by setting it low for 100ms then turns it off for 900 ms by setting the pin high. If you try that on a nucleo board it will be mostly on 90% of the time.
