[Deprecated: old core]Introducing the new delivery for STM
nikosx
Re: [Deprecated: old core]Introducing the new delivery for STM
Post by nikosx » Tue Nov 07, 2017 9:57 am
@fpiSTM : What's the correct way to reference TIM3_IRQHandler in the code and not get an error ?
Post by fpiSTM » Tue Nov 07, 2017 10:46 am
Hum, currently none as it is defined in the timer.c of the core.
As a workaround, you can comment this one in the core:
https://github.com/stm32duino/Arduino_C ... er.c#L1077
then it should be ok.
As said it will be extended and more user friendly.
nikosx
Post by nikosx » Tue Nov 07, 2017 12:09 pm
Thanks again !!!
there should be something, else why the compiler is complaining ??? :)
i'll give it a try...
nikosx
Post by nikosx » Tue Nov 07, 2017 12:20 pm
line 1077, timer.c :
void TIM3_IRQHandler(void)
if(timer_handles[2] != NULL) {
HAL_TIM_IRQHandler(timer_handles[2]);
nikosx
Post by nikosx » Tue Nov 07, 2017 12:27 pm
Found 2 time.c, put code in comment, same error....
where this file should be ?
Post by fpiSTM » Tue Nov 07, 2017 3:41 pm
could you provide the sketch you used.
In fact the error is that the TIM3_IRQHandler(void) is already defined in the core.
As it is a weak one, you should be able to comment it.
nikosx
Post by nikosx » Tue Nov 07, 2017 4:16 pm
Ok.... Does NOT compile for VS 10 + VS Arduino but it did compile and run OK for ARDUINO IDE...
it also workd OK
code below
// for ARDUINO to compile
// timer.c in
// C:\Users\Nick\AppData\Local\Arduino15\packages\STM32\hardware\stm32\2017.8.31\cores\arduino\stm32
// commend TIM3_IRQHandler
static TIM_HandleTypeDef s_TimerInstance =
.Instance = TIM3
extern "C" void TIM3_IRQHandler(void)
static boolean flag = false;
static int32_t index = 0;
if (__HAL_TIM_GET_FLAG(&s_TimerInstance, TIM_IT_UPDATE) != RESET)
__HAL_TIM_CLEAR_IT(&s_TimerInstance, TIM_IT_UPDATE);
if (flag)
flag=0;
else
flag=1;
pinMode(LED_BUILTIN, OUTPUT);
HAL_NVIC_SetPriority( TIM3_IRQn, 0, 0 );
HAL_NVIC_EnableIRQ ( TIM3_IRQn );
s_TimerInstance.Init.Prescaler = 48000; //APB1 TIM3 has 48Mhz
s_TimerInstance.Init.CounterMode = TIM_COUNTERMODE_UP;
s_TimerInstance.Init.Period = 100-1; // prescaler gives 2khz time base
s_TimerInstance.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1;
s_TimerInstance.Init.RepetitionCounter = 0;
__HAL_RCC_TIM3_CLK_ENABLE();
HAL_TIM_Base_Init ( &s_TimerInstance );
HAL_TIM_Base_Start_IT ( &s_TimerInstance );
nikosx
Post by nikosx » Tue Nov 07, 2017 4:19 pm
it became very close to code i've tried before in VS arduino and got the same error as today
TestF030.ino:31:17: error: conflicting declaration of 'void TIM3_IRQHandler()' with 'C' linkage
TestF030.ino:previous declaration with 'C++' linkage
Error compiling
Thing is VS is so much better / faster than Arduino IDE and (apart from this timer issue) works OK with ST nucleo boards....
still could not find the file that uses to change as did with arduino....
nikosx
Post by nikosx » Tue Nov 07, 2017 6:59 pm
The only way to compile in VS is to make it
extern "C++" void TIM3_IRQHandler(void)
but in this case, code does NOT run !!!!!
Post by Rick Kimball » Tue Nov 07, 2017 7:08 pm
It would be nice if you split this conversation over to a new thread nikosx. Your issues have little to do with the STM core and all to do with your choice of development tools along with misunderstanding of C vs C++ name mangling and linking.
