[Deprecated: old core]Introducing the new delivery for STM
Re: Introducing the new delivery for STM
Post by Rick Kimball » Tue Sep 20, 2016 1:01 pm
Question about the stack configuration for @Wi6Labs
In the STM32F1 core, can you explain how the stack is used? If I look at the linker file:
https://github.com/stm32duino/Arduino_C ... ASH.ld#L49
The variable _estack is set to an address in the middle of RAM.
_estack = 0x20001FFF;
In addition, it is an odd address instead of even.
Why isn't this variable set to the actually top of RAM (0x20005000) ?
Wi6Labs
Post by Wi6Labs » Wed Sep 21, 2016 1:02 pm
Rick,
It is a mistake. __estack must be set to 0x20005000, the last address of the SRAM.
We will report it to ST who will push the patch soon.
Thanks Rick.
Wi6Labs team
Wi6Labs team
Post by Rick Kimball » Wed Sep 21, 2016 3:30 pm
@Wi6Labs
What would be the best way of adding a new variant that has different pin assignments than the variants you are supplying?
[Note:]
I did read your previous answer and was looking for verification that that is indeed your solution.
You seem to say that for each board we need to create a new library? Pins seem to have their attributes described in both the variant directory and the library directory. You can't just redefine an analog pin with PWM to use another pin in the variant.cpp file, it has to also match the information in the analog.c in the library directory.
[/Note]
Wi6Labs
Post by Wi6Labs » Fri Sep 23, 2016 11:54 am
Roger / Rick,
To answer to your questions how to add a new board:
Firstly, the project is base on Nucleo boards, so there is some feature not implemented in the core code (under system/libstm32f1).
So, you need to add some code in sources (as you have already done). You should create a new folder in variant for each board added. And you should generate the library for the new board (there is a makefile in system/libstm32f1/build_gcc). This makefile must be completed with the options of the new board.
Finally, to use the board with Arduino, you should complete the board.txt with the parameters of the new board.
You are limited in pin functions. So we need to define also in analog.c the pin configuration. In variant.cpp you just signal to Arduino how the pin can be used.
BR
Wi6Labs team
Wi6Labs team
Post by stevestrong » Fri Sep 23, 2016 1:41 pm
What is actually the "pins assignment" meaning? Is it the pinout of the respective board?
So, for instance, if I have two boards with the same chip (let's say: STM32F407VET6), do I really have to make a new folder for each board variant?
Wouldn't be more effective to separate the chip variants, and not the board variants?
I mean, when I am using the GPIOs, I always use the "PAx" style, so that even if the board is different, I get the same functionality for the same pin when the same chip is used.
Or am I missing something?
Wi6Labs
Post by Wi6Labs » Fri Sep 23, 2016 2:51 pm
stevestrong,
In the Arduino spirit you have one folder by board.
In your case, we understand that the hardware of your boards (that use the same chip) is different.
So we advice you to create 2 folders in variant.
Maybe it is not the best way in your case but we are opened for other solution from the community.
Wi6Labs team.
Wi6Labs team
Post by Rick Kimball » Fri Sep 23, 2016 3:11 pm
@Wi6Labs
What if I wanted to add all the pins on the Nucleo boards and use the Morpho header with the Arduino core. What would be the best way to accomplish that?
I guess what I'm getting at, in a a round about way, is that the way the library and variants work together isn't optimal. The library has pin knowledge. I contend that any pin knowledge should only be known by the variant. I'm suggesting that the library should be just that, a set of routines that can be used with any variant and any set of pin descriptions for the same chip. Any thoughts on that?
Ollie
Post by Ollie » Fri Sep 23, 2016 3:39 pm
Rick, I do completely agree with you. The library should be available for any variant. Most of the "board" functions should be just for mapping the physical chip pins to items on the board, such as internal components or exposed pins.
+++ Ollie
Post by RogerClark » Fri Sep 23, 2016 8:34 pm
Guys
I had a couple of emails from STM and Wi6Labs, and basically it appears that Wi6 were only requested to create a system to handle Nucleo boards and hence had not designed a very flexibly architecture.
They sent me the handover document (which they said is confidential), but it doesn't contain anything that we don't already know, as its intended audience appears to be anyone that doesn't know about the Arduino IDE and the structure of the third party cores.
I'd really like to get the first pass BluePill code into the repo this weekend, so I suppose I could just action Rick's PR, but I'm still inclined to take a complete copy of libstm32 and make libstm32f103cx so that BluePill can be a variant of this, as could Maple mini
Post by Rick Kimball » Fri Sep 23, 2016 8:49 pm
RogerClark wrote: ... but I'm still inclined to take a complete copy of libstm32 and make libstm32f103cx so that BluePill can be a variant of this, as could Maple mini
seems like the best course
