[Deprecated: old core]Introducing the new delivery for STM
nikosx
Re: [Deprecated: old core]Introducing the new delivery for STM
Post by nikosx » Tue Nov 07, 2017 9:14 pm
Hi Rick.
Yes i'm not an experienced C++ programmer....
I put here the problem since i'm using STM core and not some other framework that handles timers in another way....
As far as i can see STM core does not have yet API for timer's use but has internal definitions that pose problems even using HAL to have timer & interrupts... It seems to me the problem is not that easy to solve...
I don't know somewhere else to put it since it refers only to STM core.... Have you something in mind ?
Post by Rick Kimball » Tue Nov 07, 2017 9:22 pm
Yes start another thread in this forum subsection and title it: "Problems using STM core with Visual Studio 10"
The minute you mentioned this:
nikosx wrote:Ok.... Does NOT compile for VS 10 + VS Arduino but it did compile and run OK for ARDUINO IDE...
it also workd OK
it stopped being a problem with the STM Core and a problem with your Visual Studio setup.
Post by fpiSTM » Thu Nov 09, 2017 10:26 am
Rick is right. It should be in a dedicated topic.
Anyway, I've tested your sketch.
So, first issue is the multiple definition of the TIM3_IRQHandler.
I think the best fix is to define it as WEAK.
I've tested and it is ok.
extern "C" is mandatory to avoid any c++ function name decoration.
nikosx
Post by nikosx » Thu Nov 09, 2017 4:37 pm
Hello.
a) Where do you think should the topic be ?
b) I know extern "C" is mandatoty but where should the WEEK be put ?
thanks
