Evaluation boards arrived from STM
sheepdoll
Re: Evaluation boards arrived from STM
Post by sheepdoll » Tue Oct 04, 2016 4:23 pm
Wi6Labs wrote: Indeed the I2C clock configuration for L4 doesn't work like F1. You must calculated for each speed a specific parameter which depends on the system clock.
You can find more information inside the file "twi.h".
So the STM32Cube MX tool is not used to configure the clock?
Slammer
Post by Slammer » Tue Oct 04, 2016 6:39 pm
As I understand, CubeMX passes the parameters on registers as they are (at least for I2C).... For proper operation a rather complex calculation is required, while this is not a big problem, the different parameters for different clocks, is.
I will check the mbed and Chibios how they solve this problem.....
GrumpyOldPizza
Post by GrumpyOldPizza » Wed Oct 05, 2016 11:53 am
Slammer wrote:As I understand, CubeMX passes the parameters on registers as they are (at least for I2C).... For proper operation a rather complex calculation is required, while this is not a big problem, the different parameters for different clocks, is.
MBED uses hardcoded values as well last time I checked. They run either @80MHz or @48MHz and select the set of values.
Post by RogerClark » Wed Oct 05, 2016 7:42 pm
OK.
So we could use mbed's I2C values for 80MHz
Wi6Labs
Post by Wi6Labs » Mon Oct 17, 2016 1:50 pm
We have taken account your remarks about the STM32L4 system clock settings.
A new release will be soon available with the new settings:
  • system clock at 80MHz
  • SPI default speed at 5MHz
  • I2C clock settings updated
BR
Wi6Labs team
Post by RogerClark » Mon Oct 17, 2016 8:44 pm
Excellent...
