Variant library makefile problems
Post by RogerClark » Thu Sep 29, 2016 10:48 am
Guys
I'm not an expert in makefiles, but there are 2 problems
https://github.com/stm32duino/Arduino_C ... /build_gcc
1. make clean does not appear to work, it only seems to delete the library .a file and leaves all the object files in tact
2. The output of the make / compile is sent to /dev/nul on linux, and on windows they just sent it to "NUL". However on Windows, this just created a file called NUL, which was very hard to delete (you have to do it via a command window)
My temporary fix for the NUL issue is to use NUL.txt so at least its deletable, but from what I understand it should be possible to redirect to nul on widows, some way or another
Edit
LOoks like issue 1 is caused because they used "cs-rm" Mentor Sourcery CodeBench command line
I will probably just replace cs-rm -rf
with
rm -r *
edit looks like rm -Rf works for windows as well as Linux, so I"m not sure why Wi6Labs chose to use cs-rm
Re: Variant library makefile problems
Post by Pito » Thu Sep 29, 2016 11:29 am
My experience is in windows you need "special" variants of make, mkdir, rm, cp etc to be happy.
There are various versions flying around, some will simply silently not do what you would expect :?
It took me a week to recognize that, as the makefile "worked", but some details inside were not executed properly.
Something like:
-include $(shell mkdir .dep 2>/dev/null) $(wildcard .dep/*)
does work with a right toolset under windows.
Also, for example, an "mkdir -p" with a not good "mkdir" will create a new directory called "-p" for you happily :)
The "/" vs "\" in dir_paths - that is a nightmare in makefiles run under windows - it may ignore silently the directory..
Post by RogerClark » Thu Sep 29, 2016 8:55 pm
I think using powershell seems to compile OK after some changes to the makefile
But, I will email Wi6Labs to find out their windows build env.
And it needs to be documented in a Readme.md in the system folder and at the top level. I guess I should also add a Wiki to the stm32duino github account to hold this information
I dont know if Wi6Labs are still under contract to STM, but if they are, I will see if I can get them to write the docs
Wi6Labs
Post by Wi6Labs » Mon Oct 03, 2016 12:54 pm
Roger,
The build process has been tested only under Linux OS. It explains why you have problems under Windows OS.
We don't guarantee the functionning of the library if it is generated under Windows.
We also take account your request about the documentation.
Wi6Labs team
Post by RogerClark » Mon Oct 03, 2016 8:36 pm
Build is working OK under windows, but I had to update the L4 makefile, as it did not contain the code to setup the path to the gcc toolchain.
So I copied this from your F1 makefile
You do have some references to building under windows including using codesoucery tools, but I will change this to work without those tools.
PS. i thought the document you emailed to be was confidential, and hence I could discuss its contents.
